rverdoold Posted August 11, 2006 Share Posted August 11, 2006 Hi everyone, I got my hands on the Haynes manual (89100) which seems pretty nice, except a few things. It only handles the 2.2 and 2.5, but EJ20 from 1st 1991 series is same as EJ22 (i thought) and all measures are only in imperial (but a good conversion table is provided). I am going to do everything myself on this car because dealers are also not so populair here in holland, and i am handy enough. The Legacy wagon from 1991 with non-turbo EJ20 and automatic runs great still after 220.000 km (not a lot but lots above 120 miles/hour). Only the 4eat has been rebuilt cause some parts inside were molten togehter after it overheated at 125 mls/h (:cool: ) but my parents let it rebuild. I was looking in chapter 6 about the emission in section 6-13 and 6-14 the EGR valve is described but if i look on the photo's and under the hood i can not find the valve on my 1991 EJ20 (non-turbo, LHD). It should be right behind the intake manifold across the brakefluid resevoir but my EJ20 has notting there which looks like a valve there some empty threadholes on the cylinderhead which could be for the EGR but might also be for the a/c which i also do not have. Is the european model not equiped with an EGR valve or is it located somewhere else on the block? The illustration on 6-13 (6.2 typical EGR system) shows an tube going into the intake manifold through on of the intake pipes, i have not seen this on my block. Small second question: are the tightening tourques for the the bolts as in the haynes for the 2.2 soch the same as for the 2.0 soch because it is the same engine with just smaller bore? Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted August 15, 2006 Share Posted August 15, 2006 You shouldn't have the EGR valve. The manual probably encompasses several years of the legacy, and the later models had EGR valves, yours does not. The specs for torquing should be the same or close enough between the 2.0 & 2.2 Josh Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted August 15, 2006 Share Posted August 15, 2006 First thing that I would do is wait for a cold day and then burn that manual. Other then that follow what Legacy777 said. They may cost more, but you can't go wrong with a factory manual. Quote Link to comment Share on other sites More sharing options...
