Guest johnk Posted August 6, 2003 Share Posted August 6, 2003 I need to replace the AC compressor and drier in a 93 Impreza. How difficult will this to do on my own. Do I need any special tools beyond a compressor and air tools> Thanks Quote Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted August 6, 2003 Share Posted August 6, 2003 Not very difficult. If you have R12, I'd suggest converting it to 134a. I've got a pretty detailed write-up in the archives http://www.ultimatesubaru.org/forum/showthread.php?t=2442&page=1&pp=10&highlight=134a Quote Link to comment Share on other sites More sharing options...
Guest kevinsUBARU Posted August 6, 2003 Share Posted August 6, 2003 what are the signs that these components are wearing out? In my 95 Impreza, When I turn the AC on, a chirp can be heard from the engine bay (it was squeeling last summer but I had the belts tightened up), and it spews red dust all over the place. Inside the cabin, I can hear it "hissing" through the vents. Quote Link to comment Share on other sites More sharing options...
Guest theotherskip Posted August 7, 2003 Share Posted August 7, 2003 you don't even need a compressor & air tools. actually, hand tools tend to be better. there is far less chance of really screwing things up, assuming that you are using the proper tool. with the exception of the occasional frozen bolt which an impact gun can help, i never use air tools, especially when putting things back together... as for special tools, you will need a vacuum pump to evacuate the sytem, but it might be best to have the system evacuated and charged at a shop. make sure they add the proper amount of oil to the system. Quote Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted August 7, 2003 Share Posted August 7, 2003 Kevin, If the belts are tight, and you're still getting squealing and tons of red dust. I'd say at the very least the clutch is dieing/dead, or the compressor needs to be replaced. If you do the work yourself, put the oil in yourself and just have them evacuate the system and put the refridge in. Quote Link to comment Share on other sites More sharing options...
sillybilly Posted June 23, 2005 Share Posted June 23, 2005 I can't find the detailed write up of this article. Anyone have a suggestion on DIY AC compressor replacement? THanks, BIlly Not very difficult. If you have R12, I'd suggest converting it to 134a. I've got a pretty detailed write-up in the archives http://www.ultimatesubaru.org/forum/showthread.php?t=2442&page=1&pp=10&highlight=134a Quote Link to comment Share on other sites More sharing options...
NorthWet Posted June 23, 2005 Share Posted June 23, 2005 You might try sending a PM to Legacy777. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 24, 2005 Share Posted June 24, 2005 here ya go http://www.ultimatesubaru.org/forum/showthread.php?t=2442&page=1&pp=10&highlight=134a Like I said in the most recent post....I'd use PAG 100 oil instead of the esther 100 oil. Other then that, it should be good. Quote Link to comment Share on other sites More sharing options...
