ej swap......
offroadsubaruguy
After swapping in a cheap 97 2.2L, I questioned why I didn't just do a 2.5L motor. Anyone know of a good place to locate any of the new 2.5L?
I haven't looked at an OBDI harness, is the wiring that much different?
The check engine light is nice to have working (if you leave things stock) lets you know when somethings not working right.
At 135-140 you are really at the reliability limit of the 5mt D/R and pushing it further up to over 150 hp you may be getting into replacing syncro's and gears at a rapid rate.
Sure, some probably have run higher horse on a EA tranny, but if you want to keep it for a while, i wouldn't reccomend it.
Which brings us back to... "wouldn't it be nice to have a supply of the newer gen Dual ranges?":brow:
