My 98 Forester's temp gauge tends to drop down to the bottom for no apparent reason. Today I was doing 70 on the highway, and the temp needle just plunked to the bottom of the gauge. It had been holding steady about half way up for several minutes. What's the problem? or is this normal? It was was well over 32F at the time. Thanks!
If you have the tools, the place to work, and the time, pull the coolant temp sensor. The temp sensor in my 55 Thunderbird started becoming erratic this summer, with readings all over the guage, changing several times in a 5 minute period from 25% to 85% to 0% to 90% and back to 60% readings. I pulled it and put it in a cold pan of water on the stove and hooked a multimeter to its body and the terminal. As I turned up the heat to get the water to a boil, the multimeter readings did exactly the same dance as the temperature guage had done in the car. Obviously the temp sender was bad. Good Luck!
  • 3 weeks later...
For those of you keeping track of this.... According to the shop, it's the thermostat. The shop INSTALLED the thermostat because there was NO thermostat to begin with. But I don't see how the lack of a thermostat would make the needle suddenly drop. Maybe not enough in the pressure? And why would it go up and then down... I have a feeling I'll need to replace the sensor anyway.
how could it not have a thermostat? the temp guage would never move if it were missing, it certainly wouldn't reach the mid point on the guage. you'd have almost no heat. ?.?.? the ecu would always think it was just starting up. maybe in texas it's hot enough...
how long have you had this car.?
Makes sense. Local driving there isnt enough air moving over the radiator to pull out all the heat. Highway driving the amount of air through the radiator will remove all the heat and cool the engine.
Subaru thermostates are 180-190 degrees. At mid point on the temp gauge that is around 190-200 degrees reading off the ecu using a scangauge. As you can see it doesnt take much to pull the heat out of the engine without the thermostat.
This is not a big heat producing engine when its cold outside. Thats why you get no heat without a thermostat.
nipper
It's Houston Texas! I've had it a couple of months now.
Hey.....another Houstonian :)
Do you know if the shop put in a subaru thermostat? If not, you still may have some issues. Don't ask me why, but Subaru engines act weird if they don't have a subaru thermostat in them.
BTW, you may want to check out the texas forum on http://forums.nasioc.com/forums
There are local get togethers every week, and state meets at times throughout the year.
If you still have problems with the car, let me know, I could take a look at it.
Josh
Thanks! I forgot to mention.... I took it into the shop because the check engine light came on. Two codes: misfire, and fuel sending unit. New wires took care of the misfire. Subaru wanted $130 for the sending unit. I figured I'd go ahead and change the pump and strainer while I'm in there. Subaru wanted $445 for the pump. Wow. I hope I didn't do the wrong thing by buying the pump, strainer AND strainer for around $120 altogether off ebay. I got the Bosch pump and OEM Subaru sending unit.
Josh
er um....
You wont get a code for a fuel sender. Its not even part of the ECU circuit.
Subarus have notorously bad fuel senders that can usually be made better with Techron fuel additive.
Personally i would say unless the sender is dead, do the techron thing.
I have never bought major parts off ebay that were not OE. Luckily its something thats easy to get to.
nipper
Okay, thanks. Funny the shop even gave me the number of the code. For fuel sending unit, the fuel gauge thing at the tank. I could be mistaken. I have noticed that whenever the fuel gauge needle takes a sudden dive to "empty", the check engine light comes on shortly after that. Then, when I put some gas in the tank and the needle comes back to life and settles at its correct position, the check engine turns off. :confused:
er um....
nipper
Ok next time that happen have the codes read at an autopart sotre for free. I think that has more to do with your EVAP system then anything else.
What code number did they give you.
nipper
