mortimc Posted December 12, 2006 Share Posted December 12, 2006 I am putting a 1985 MPFI turbo EA82 in an 88 SPFI wagon I have already installed the engine, the engine bay portion of the wiring harness, and the computer. All the prepherial things work, including the starter. But there is not power to the fuel pump or the starter. Many of the plugs were the same but I have a feeling that doesnt mean anything. Many other plugs are still homeless. Looking for any experienced help. Clayton Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 12, 2006 Share Posted December 12, 2006 You're gonna need a home for all those plugs. And i believe the fuel pump is run differently with the MPFI than it is with the SPFI, in regards to the disty telling the pump to turn on in the SPFI. Quote Link to comment Share on other sites More sharing options...
calebz Posted December 12, 2006 Share Posted December 12, 2006 You are dealing with two completely different fuel and ignition systems. Don't count on anything plugging in and working. Noah is onto something RE: different pump triggering, but its not a difference between turbo and SPFI, its a difference between the 85-86 fuel/ignition system and the 87+ system. Time to bust out the wiring diagrams for each. Quote Link to comment Share on other sites More sharing options...
mortimc Posted December 13, 2006 Author Share Posted December 13, 2006 I do have the both complete factory service manuals for the 88 and 85, but I was hoping that perhaps someone has dealt with this before so they could point me in the right direction before I dive in. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 14, 2006 Share Posted December 14, 2006 The turbo uses a higher pressure fuel pump as well. Best thing to do is just swap the turbo dash harness into the car. The rear harness/dash harness connection will be a lot easier to figure out. GD Quote Link to comment Share on other sites More sharing options...
mortimc Posted December 15, 2006 Author Share Posted December 15, 2006 Doesnt the SPFI use a higher pressure pump, I coulda sworn I saw that in the FSM Quote Link to comment Share on other sites More sharing options...
calebz Posted December 23, 2006 Share Posted December 23, 2006 Doesnt the SPFI use a higher pressure pump, I coulda sworn I saw that in the FSM Don't think so. I don't have the numbers in front of me, but I am about positive that the FSM rates the turbo pump at 60-70 PSI and the SPFI pump is a bit less than that. Quote Link to comment Share on other sites More sharing options...
Dylan86GL10 Posted December 28, 2006 Share Posted December 28, 2006 On the turbo, the ECU grounds both the fuel pump relay and the fuel pump. Compare to the SPFI and at most you'd have to run another wire or two from the ecu connector back to the pump connection. http://dodgeneon.net/subaru/ Quote Link to comment Share on other sites More sharing options...
