rwilcox Posted April 17, 2007 Share Posted April 17, 2007 I have the motor and tranny and a huge mess of wires i took from a 1990 legacy. and i have a ton of questions first is the 2wd tcu the same as awd tcu? is there a place to find what wires out of that mess i need and which ones i can do away with? or am i better off going with an aftermarket ecu and harness would rather not because there big money. is what i am wanting to do possible? thanks ralph Quote Link to comment Share on other sites More sharing options...
the_postie Posted April 17, 2007 Share Posted April 17, 2007 2wd and awd ecu are the same but the tcu is not.I have managed to get a 2wd tcu to run a awd box ,which would probably be ok in a sandrail. Quote Link to comment Share on other sites More sharing options...
rwilcox Posted April 24, 2007 Author Share Posted April 24, 2007 is the harness the same from 2wd to awd I am also trying to find someone to do my harness for me and am haveing a little trouble. so if you read this and can do a harness or know someone that can please call me at 317-514-9894 anytime day or night. I would really like to get this part of the project started. thanks ralph Quote Link to comment Share on other sites More sharing options...
the_postie Posted April 24, 2007 Share Posted April 24, 2007 No the awd auto harness has a couple of extra wires.The plugs are the same at the gearbox and tcu end ,some models have the pinning slightly different but you can move these.It would be easier if you want awd to use a awd loom but you can add the the wires and pins to a fwd loom.Also you need to keep the speed sensor to make it shift properly,awd drive have 2 one on the box one in the dash.The front wheel drive speed sensor uses the dash one as a back up so you can get away with just the one on the box .You can use a aftermarket one vw guys know about these.Stripping the loom is time consuming first time round.Early subaru auto looms[series1] are harder to strip than later models. Quote Link to comment Share on other sites More sharing options...
Snowman Posted May 2, 2007 Share Posted May 2, 2007 Look in the vendor sales forum on here. There are a couple of guys that do EJ swap harness prep for like $200...having done the swap myself, I would call it money well spent. By the time you buy the FSM you need to figure out which wires are which, you're nearly halfway to $200 anyway. Quote Link to comment Share on other sites More sharing options...
