DIXON99011 Posted June 24, 2007 Share Posted June 24, 2007 what years are best for this operation??I have an auto trans should I try to find 2.2 out of an auto?? Quote Link to comment Share on other sites More sharing options...
hankosolder2 Posted July 9, 2007 Share Posted July 9, 2007 what years are best for this operation??I have an auto trans should I try to find 2.2 out of an auto?? You want an engine out of a '95 Legacy 2.2 automatic, complete with the intake manifold, wiring harness, etc. It'll plug straight in, more or less. Search the New Generation forum for more info- this topic has been covered extensively. Nathan Quote Link to comment Share on other sites More sharing options...
AZTOAK Posted July 13, 2007 Share Posted July 13, 2007 I am doing this right now, same year even, and am having some silly problems before I hardly get started. :-\ Here it is. Good luck. http://www.ultimatesubaru.org/forum/showthread.php?t=76890 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 14, 2007 Share Posted July 14, 2007 the easiest is a 2.2 with an EGR valve. if you get a 1995 the only added bonus is that they have dual port exhaust liket he 2.5 so the 2.5 existing exhaust bolts right up. if you get another year 2.2 with EGR, just get the exhaust/ ypipe with it and bolt that up. it's that simple. you can bypass the EGR system as well, but that takes some extra work. Quote Link to comment Share on other sites More sharing options...
monstaru Posted August 12, 2007 Share Posted August 12, 2007 do a 95.that way you have nothing else to worry about.it is like pulling the same motor out that you are replacing.a short block that is.simple as pie. Quote Link to comment Share on other sites More sharing options...
