obskermit Posted September 5, 2007 Share Posted September 5, 2007 The motor on my passenger side window has apparently siezed up. the repair bill is going to be $339.15.... Any advice before i do this? my vehicle is a 2000 Subaru Outback Sport. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 5, 2007 Share Posted September 5, 2007 Provided the motor is faulty and it's not the regulator jammed up or something like that. 61188AE00B WINDOW MOTOR FRONT RIGHT FOR 2000-2004 LEGACYS ALL msrp $210 Quote Link to comment Share on other sites More sharing options...
RallyKeith Posted September 5, 2007 Share Posted September 5, 2007 Provided the motor is faulty and it's not the regulator jammed up or something like that. 61188AE00B WINDOW MOTOR FRONT RIGHT FOR 2000-2004 LEGACYS ALL msrp $210 Outback sport = Impreza use http://www.car-part.com You can get a used one as cheap as $35 + shipping. Keith Quote Link to comment Share on other sites More sharing options...
Cougar Posted September 5, 2007 Share Posted September 5, 2007 As others hinted at, make sure the motor is bad before you condemn it. It doubt that it is bad but it could be jammed. Test it after it is freed up by connecting power directly to it. Quote Link to comment Share on other sites More sharing options...
RallyKeith Posted September 5, 2007 Share Posted September 5, 2007 As others hinted at, make sure the motor is bad before you condemn it. It doubt that it is bad but it could be jammed. Test it after it is freed up by connecting power directly to it. Good point.... The stealership told my aunt she needed a new driver's side power window switch on her 91 Legacy, and of course wanted to charge her loads of money. I got one at a junk yard and did the swap. Turned out her switch was just fine, it was the wiring harness to the door. One of the was had broken internally and only made intermittant contact. Keith Quote Link to comment Share on other sites More sharing options...
nipper Posted September 5, 2007 Share Posted September 5, 2007 ALot of times its the switches that are bad, and they can be rebuilt. The contacts get carbon build up. Its really easy to fix. nipper Quote Link to comment Share on other sites More sharing options...
obskermit Posted September 5, 2007 Author Share Posted September 5, 2007 Update! - So they couldnt get the part without ordering it. and they said 3 days. so i went back and picked up my car. went to get some lunch and on the way back to my office i got the inclination to try it again, and to my suprise it went back up. I decided to throw caution to the wind ans try to put it back down, and nothing. details are. i tried to put it up from the drivers side. then the passenger side switch. the passenger side switch worked. (it did not before) The driver side had stoped working all together the day before it went down and stayed down using the passenger side switch. Needless to say now that its up, i canceled the parts order. and i have the luxury of time to address the problem. Quote Link to comment Share on other sites More sharing options...
obskermit Posted September 5, 2007 Author Share Posted September 5, 2007 Provided the motor is faulty and it's not the regulator jammed up or something like that. 61188AE00B WINDOW MOTOR FRONT RIGHT FOR 2000-2004 LEGACYS ALL msrp $210 What is the regulator? and how would it get jammed up - could i fix it? Quote Link to comment Share on other sites More sharing options...
obskermit Posted September 5, 2007 Author Share Posted September 5, 2007 ALot of times its the switches that are bad, and they can be rebuilt. The contacts get carbon build up. Its really easy to fix. nipper Are you talking about the actual switches on the door handles, or are there switches near the motor? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted September 5, 2007 Share Posted September 5, 2007 Quote Link to comment Share on other sites More sharing options...
Cougar Posted September 5, 2007 Share Posted September 5, 2007 From the sounds of it, it seems to me you have some switch problems. Possibly also some wiring problems in the door jamb. Quote Link to comment Share on other sites More sharing options...
obskermit Posted September 5, 2007 Author Share Posted September 5, 2007 From the sounds of it, it seems to me you have some switch problems. Possibly also some wiring problems in the door jamb. So what do i do? is it hard to take the inner door off to see if somthing i jammed up mechanically? What might it mean since the driver side switch doesnt do anything and the passenger side will put it down but not up. and it all went bad at the same time. I doubt both switches would crap out at the same time would they? Quote Link to comment Share on other sites More sharing options...
Cougar Posted September 5, 2007 Share Posted September 5, 2007 I think the power for the passenger switch has to pass through the driver side switch first so that would point to it as the possible trouble. The driver's door panel can be pryed loose by using a small putty knife. There are some plastic retainers in the around panel edges You will feel them as you slide the blade around under the edge. Carefully pry them out as they can break through the panel if you are not careful. Once you get at the switches try spraying the contacts with some spray cleaner. If you try to take the switch apart be fore-warned there are small springs in the switch that will fly out if the switch is opened. I would take it apart in a plastic bag if you do that but if you can avoid taking it apart I would. Quote Link to comment Share on other sites More sharing options...
AKghandi Posted December 24, 2011 Share Posted December 24, 2011 ALot of times its the switches that are bad, and they can be rebuilt. The contacts get carbon build up. Its really easy to fix. nipper it is indeed. just did one earlier just dont loose any of the tiny pieces in the carpet. Quote Link to comment Share on other sites More sharing options...
Cougar Posted December 24, 2011 Share Posted December 24, 2011 It is a good idea to place the switch in a clear plastic bag and then work on it. If parts fly at least the bag should contain them. Quote Link to comment Share on other sites More sharing options...
95legwagon Posted December 25, 2011 Share Posted December 25, 2011 Outback sport = Impreza use http://www.car-part.com You can get a used one as cheap as $35 + shipping. Keith look for south windsor auto parts on there thats where i work and i KNOW we have legacy's and outback's and newer imps. good luck! Quote Link to comment Share on other sites More sharing options...
