mcbrat Posted June 23, 2011 Share Posted June 23, 2011 Or... I could buy one from the dealership. Just called them, they are still available! WOOT! Should be here saturday I'd get 2. what are the chances of finding a 41 year old part still available from the dealer! Quote Link to comment Share on other sites More sharing options...
backwoodsboy Posted June 23, 2011 Share Posted June 23, 2011 The bearing shows flags on the older EA cars (gen 2) in my catalog. Im guessing thats why theyre available still. Theres 19 qty showing avail at the current moment. Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 24, 2011 Author Share Posted June 24, 2011 FUuuuuuuuuuuuuuuu Now that my washers arrived (thanks again Mark) I went to bolt on the flywheel, but now I realize I'm MISSING two bolts for the flywheel because the 1100 only had 6 bolts and I never got bolts for this 1400 flywheel! The worst part? Its a 9mm x 1.00 pitch bolt, which apparently nobody carries Quote Link to comment Share on other sites More sharing options...
Datsunrides Posted June 24, 2011 Share Posted June 24, 2011 Well, I know I have the bolts, as I removed them to get you the washers. If you can wait, I can gather a few up and send them out, only this time I will let the post office weight them to determine postage, so it won't take a week to get there. Mark Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 24, 2011 Author Share Posted June 24, 2011 Well, I know I have the bolts, as I removed them to get you the washers. If you can wait, I can gather a few up and send them out, only this time I will let the post office weight them to determine postage, so it won't take a week to get there. Mark Let me see if I can find something locally first. I'd REALLY like to get the drivetrain installed this weekend, but if I can't, I guess I'll have to use those. BTW, what size are the bolts? IE bolt head size. Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 24, 2011 Author Share Posted June 24, 2011 I went to 4 different places, finally wound up at a place that had more metric bolts than I've ever seen in my entire life... Isles and isles of them! And still no 9mm bolts... :-\ Quote Link to comment Share on other sites More sharing options...
moosens Posted June 24, 2011 Share Posted June 24, 2011 (edited) These guys always seem to help. http://www.nutty.com/ Then again might have to contact them. Didn't see it upon quick search. But they'll show more if you contact them. Good luck. Edited June 24, 2011 by moosens Quote Link to comment Share on other sites More sharing options...
Datsunrides Posted June 25, 2011 Share Posted June 25, 2011 Let me see if I can find something locally first. I'd REALLY like to get the drivetrain installed this weekend, but if I can't, I guess I'll have to use those. BTW, what size are the bolts? IE bolt head size. The ones I'm sending are 14mm. Mark Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 25, 2011 Author Share Posted June 25, 2011 The ones I'm sending are 14mm. Mark OK good, they should be the same then. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 27, 2011 Share Posted June 27, 2011 (edited) Whoops my phone finished loading the rest of the thread. Lookin good Steve! Edited June 27, 2011 by Caboobaroo Quote Link to comment Share on other sites More sharing options...
rat fink Posted June 27, 2011 Share Posted June 27, 2011 Wow, this has certainly been a labor of love. I'm blown away. Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 27, 2011 Author Share Posted June 27, 2011 Just got the flywheel bolts! Thanks again Mark!!! But I have one question, how do I test whether or not the clutch is disengaging properly? Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 28, 2011 Author Share Posted June 28, 2011 I double checked my "custom" clutch disc, its the same thickness as the factory new one I have, so thats not a problem. But for some reason when I disengage the clutch, everything still spins. This is while the drivetrain is off the car. I double checked the clutch fork, its fine. The thing I'm concerned with is the clutch pressure plate seems too compress a lot when installed. Is it supposed to do that? How far should the pressure plate "leaves" go down when its installed? Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 28, 2011 Author Share Posted June 28, 2011 OK, I checked the pressure plate and its the same as the old pressure plates... Installs the same, acts the same, can't see a problem there. I can't tell whats going on :-\ Quote Link to comment Share on other sites More sharing options...
mcbrat Posted June 28, 2011 Share Posted June 28, 2011 how are you spinning stuff? are you sure it's fully disengaging the clutch disc? Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 28, 2011 Author Share Posted June 28, 2011 how are you spinning stuff? are you sure it's fully disengaging the clutch disc? Spinning with the crankshaft. I'm not sure its disengaging the clutch disc, thats my problem. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted June 28, 2011 Share Posted June 28, 2011 if the clutch disc is the same thickness, and the pressure plates are the same, then you might not have enough pressure on the clutch fork to disengage if it's still spinning the trans stubs. trying to disengage the clutch while spinning the crank would be a difficult job for one person, so I assume you have someone helping? does trans in nuetral stop the spinning....? (should) Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 28, 2011 Author Share Posted June 28, 2011 Neutral doesn't spin, 1rst gear spins, reverse spins. Right now, I've taken the bellhousing off and I'm testing all my configurations of flywheels and bellhousings to see if there is a clearance difference, and there does appear to be one... I'm going to try one more thing, which is using the modified bellhousing that is about 3mm shorter than the one I had on the car (the 1400) and see if maybe it gets more pressure from the clutch fork. From my measurements, the throwout bearing had about 1cm before it comes into contact with the pressure plate springs, I don't know if that is correct or not. Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted June 28, 2011 Author Share Posted June 28, 2011 Alright, I installed the modified bellhousing and that extra 3mm made a difference. I tested it out, and the clutch does disengage now when you pull the fork back really hard (before I pulled it back full strength and absolutely nothing happened). I installed the 1100 bellhousing and set the 1100 flywheel on there (cant bolt it down cause of the bolt patten) and instantly could tell for some reason the 1400 flywheel and bellhousing has the flywheel sitting more "recessed" into the bellhousing. So I checked the other modified bellhousing, and it almost matched up to the 1100 (not perfect, but within a mm or so). Its as good as its going to get now for sure... So the question is, who wants to help me install the drivetrain? Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted July 1, 2011 Author Share Posted July 1, 2011 *twiddles thumbs* Quote Link to comment Share on other sites More sharing options...
Pooparu Posted July 1, 2011 Share Posted July 1, 2011 mmmmmmmmmmmmmm, tasty Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted July 4, 2011 Author Share Posted July 4, 2011 Drivetrain is now in the car!!! Special thanks to Adam for letting me borrow (with a small payment ) his almost-new Harbor Freight engine lift!!! Quote Link to comment Share on other sites More sharing options...
Leeroy Posted July 4, 2011 Share Posted July 4, 2011 I want to say beautiful but think delicious is a better word! Looks good enough to eat off Kosta! Great work, you must feel it is getting closer to finished now. Cheers Lee Quote Link to comment Share on other sites More sharing options...
Firespray401 Posted July 4, 2011 Share Posted July 4, 2011 HIZAH! Looking excellent! Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted July 4, 2011 Author Share Posted July 4, 2011 Great work, you must feel it is getting closer to finished now. A bit closer yes, but the amount of problems that constantly pop up and have to be solved slows everything down... For example, I just discovered the air box I bought doesn't clear the hood :-\ This means I have to ditch the velocity stacks under it too since even with JUST those on, they are only like 1/2" from the hood... Small problems like that keep stacking up. I still have to build a rear transmission mount as well, but that might not be TOO difficult if I do it right. Quote Link to comment Share on other sites More sharing options...
