TomRhere Posted October 28, 2007 Share Posted October 28, 2007 The one above the rear diff on the '85 BRAT is shot, as in nothing left to the rubber. Anybody know of a replacement bushing? I haven't found one listed anywhere I've looked on-line. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 28, 2007 Share Posted October 28, 2007 I've heard of that happeneing before, but never seen it in person. I would guess that's a dealer only item. Possibly the old one was destroyed by a partially frozen u-joint? Just a guess. There's good used ones to be had around here if you need me to pull one. GD Quote Link to comment Share on other sites More sharing options...
TomRhere Posted October 28, 2007 Author Share Posted October 28, 2007 I was thinking it would be a dealer only item, but didn't see it listed on the two dealer sites I tried. I just may take you up on the offer to pull one. After posting the start of this thread, I thought of that ureathane motor mount repair, thinking maybe I will try that first, just to see. If it works, it'll save both of us some grunt work. I did have a u-joint go bad, but that was just recently and I haven't drove BRAT much since the 242 mile drive home at purchase time, got about 500 on it now with longest drive being about 65 miles. No vibration/noises on the drive home, but now I have them. Did a rear disc swap when I couldn't get the adjusters freed up. Now, there's a cyclic rumble from somewhere, I can't pin-point it. It's not in time with tire rotation, and it has it's own beat, if you will. I have double-checked rear brakes for anything out of order, nothing rubbing that I can find. Rear axle nuts were not to torque when I removed them, basically finger tight, so I'm thinking the bearings might be damaged. New ones on the way... Purchased and installed new u-joints Friday last, that's when I found the bushing shot. Drove BRAT about 50 miles afterwards, developed a major vibration and deemed it to be from the driveshaft for what ever reason. Pulled a couple u-joints from spare driveshafts and cleaned/re-greased them. Put them in and swapped shaft again, way less vibration. But,,, these u-joints are much looser than the new ones, so maybe it was that the bushing being shot is culprit for vibration before with the new ones. Wife has decreed that "HER" BRAT will be 100% before she drives it. So I'm replacing stuff. Have ball-joints, inner/outer tie-rods on order. PS inner tie-rod has a bit of play, so I'm just replacing all of it. New front bearings and seals are here. New tires are on the list also, got two different brands on it, not good... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 28, 2007 Share Posted October 28, 2007 Try McMasters for some two part urethane. You should be able to remove the mount and cure the urethane in an oven. Should be hard as nails, but will cost a pretty penny for the urethane. Might be worth the cool experiment though! I've wanted to try that stuff for a while. GD Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 28, 2007 Share Posted October 28, 2007 i needed one for one of my old XT6's and they could be had for $70 from the dealer, though i think the price is now in the triple digits and this part should be the same on the EA82 it might be worth a shot. there's enough good used ones around though. i got lucky, one of my XT6's had a brand new one on it, so i've kept that one on my own daily driver. Quote Link to comment Share on other sites More sharing options...
Moodybluesr Posted October 28, 2007 Share Posted October 28, 2007 IIRC Tubone had a couple laying around; he sent me one for Ruby Sue just before I sold her. May want to send him a pm. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted October 28, 2007 Author Share Posted October 28, 2007 I'll look into that 2-part stuff. If I go that route, I'll be sure and post on the outcome of it. Not to sure Wife will go for me baking it in the oven though. "But Honey, I'm fixing your BRAT doing this" This BRAT is from Nevada via the one I bought it from, originally from Arizona so I found out thumbing thru the owners manual the other day. So maybe those bolts won't kick my butt when I attempt to remove them. You just don't remove bolts on a vehicle that's seen road salt all it's life..... Quote Link to comment Share on other sites More sharing options...
Turbone Posted October 28, 2007 Share Posted October 28, 2007 IIRC Tubone had a couple laying around; he sent me one for Ruby Sue just before I sold her. May want to send him a pm. Past tense now. Been sent out to needy owners :-p I plan on making a trip to the PAP later this week, I'll see if theres any good ones there. How many miles on your Brat Tom? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 28, 2007 Share Posted October 28, 2007 You just don't remove bolts on a vehicle that's seen road salt all it's life.....quit lying!!!!! sure they do - the head rounds itself off, then you go to alternate means and the head shears off leaving everything else still rustwelded together for you to drillout. i *might* have one if turbone can't come up with one. consider me a last resort, a very last resort. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted October 28, 2007 Author Share Posted October 28, 2007 The '85 BRAT has just over 111,794 showing on the odo, not 100% sure if it's actual but believe it to be. I need to get some pics taken and put up for all to see..... If someone wants to grab one of those mount bushings for me I'd be greatful. Won't have any "extra money" until next paycheck though. I'll try that urethane on the one I take out, maybe put it in the '86 BRAT. And Gary, maybe I should've worded that different. As in "you ""don't just"" remove bolts" instead of "you ""just don't"" remove them" But you hit that nail squarely on the head........ Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 28, 2007 Share Posted October 28, 2007 85 brat - so this is an EA81? are EA82 and EA81 rear diff mounts different? try the parts wanted forum too...not trying to step on turbone's feet or anything, but i'm just assuming he won't mind not removing one? Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted October 28, 2007 Share Posted October 28, 2007 Rock on , a fello sube nut in Michigan Quote Link to comment Share on other sites More sharing options...
DahlEd Posted October 29, 2007 Share Posted October 29, 2007 Is this what you're looking for? [http://www.ultimatesubaru.org/photos/showphoto.php?photo=17904&cat=500] Quote Link to comment Share on other sites More sharing options...
Turbone Posted October 29, 2007 Share Posted October 29, 2007 Is this what you're looking for? ["]http://www.ultimatesubaru.org/photos/showphoto.php?photo=17904&cat=500] Yup, thats the little bugger. But its attached to a flat plate and 4 long bolts that attaches it to the diff. All EA81 and EA82 mounts are the same 1 Quote Link to comment Share on other sites More sharing options...
DahlEd Posted October 29, 2007 Share Posted October 29, 2007 The bushing is not sold by itself . . . at Subaru dealers. You have to buy the whole assembly . . . the plate w/bushing and 4 spindles. As I recall, it cost me about ~$160 in 2006. I don't know if it can be found elsewhere without buying the whole assembly. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted October 29, 2007 Author Share Posted October 29, 2007 Didn't think one could get just the bushing, and one would have to get the whole assembly. I have the complete rear unit out of my old '86 BRAT, I looked at that mount before starting this thread. That bushing is bad also, but I got a good picture of how it goes together/comes apart better than lying under the '85 BRAT. But $160.00 or better for new is way to much in this ones opinion. Quote Link to comment Share on other sites More sharing options...
joostvdw Posted October 29, 2007 Share Posted October 29, 2007 I don't know how complicated this bushing is, but can't you get a machine shop make you a nylon replica? shouldn't be too hard or too expensive and lasts a live time. Quote Link to comment Share on other sites More sharing options...
