chadwick35/04 Posted November 17, 2007 Share Posted November 17, 2007 I had a post before about my dealer having to repaint the inside of my trunk do to rust around the spoiler bolts and they put the old spoiler back on and then vibrating started from there, so then they replaced it with a new one and now it is vibrating again especially when it is cold out. Now here is the deal, the dealer verbally told me they heard the noise and told me that there is nothing further they could do, so on the repair order they put down no problem found no repair made which under warranty purposes you are supposed to state that, I worked at a dealer so I know that so what that did was pretty much dismiss the sitaution, so they said two things actaully, they heard it but put down no noise heard no problem found no reapir made, so I called subaru on the issue and I have another apt with the dealer again next week for the issue I have to drive with the tech or body shop guy to hear the noise that is obvious but not to them. Shady situation to me but pissed off at the dealer big time. Could it be the spoiler or the trunk making this noise remember the trunk was removed to fix and repaint.I would appreciate as much feedback on this sitaution as possible. thanks:mad: Quote Link to comment Share on other sites More sharing options...
beataru Posted November 17, 2007 Share Posted November 17, 2007 Well hold on there, Im lost, when does the noise happen when your moving at a high rate of speed, like 40ish or does it happen when your at idle or all the time or what? Quote Link to comment Share on other sites More sharing options...
ericem Posted November 18, 2007 Share Posted November 18, 2007 How can a spoiler cause so much grief??!!!!! Maybe you should look into taking it apart yourself. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 18, 2007 Share Posted November 18, 2007 Ok - I'm about sick of this foolishness: Now here is the deal, the dealer verbally told me they heard the noise and told me that there is nothing further they could do, so on the repair order they put down no problem found no repair made which under warranty purposes you are supposed to state that, I worked at a dealer so I know that so what that did was pretty much dismiss the sitaution, so they said two things actaully, they heard it but put down no noise heard no problem found no reapir made, so I called subaru on the issue and I have another apt with the dealer again next week for the issue I have to drive with the tech or body shop guy to hear the noise that is obvious but not to them. Shady situation to me but pissed off at the dealer big time. This is NOT all one sentence. Learn to form sentences, and use the proper punctuation and spelling or you aren't going to get many people to read your rant - let alone give you advice or their opinion. I feel your frustration, but you need to slow down and make yourself understood. Communication is key - both here, and with Subaru. Sound like a fool, and sure as $hit you'll be treated like one too. GD Quote Link to comment Share on other sites More sharing options...
chadwick35/04 Posted November 19, 2007 Author Share Posted November 19, 2007 How can a spoiler cause so much grief??!!!!! Maybe you should look into taking it apart yourself. It is amazing isn't it? I would love to get into it myself but not sure if it would void warranty in case something further happens, if I had a garage that would be cool also, but very cold here now and tough to do ya know, thanks for responding man! Quote Link to comment Share on other sites More sharing options...
chadwick35/04 Posted November 19, 2007 Author Share Posted November 19, 2007 Well hold on there, Im lost, when does the noise happen when your moving at a high rate of speed, like 40ish or does it happen when your at idle or all the time or what? Hi thanks for replying man! It happens in the cold ok, and when you put car in gear and start off, and at a steady speed of at least 30mph ,and also when I am stopped at a light or sign you can hear the vibrating in the rear bad when I am at idle. Much more pronounced in cold then warm. Quote Link to comment Share on other sites More sharing options...
chadwick35/04 Posted November 19, 2007 Author Share Posted November 19, 2007 Ok - I'm about sick of this foolishness: This is NOT all one sentence. Learn to form sentences, and use the proper punctuation and spelling or you aren't going to get many people to read your rant - let alone give you advice or their opinion. I feel your frustration, but you need to slow down and make yourself understood. Communication is key - both here, and with Subaru. Sound like a fool, and sure as $hit you'll be treated like one too. GD Yeah at that time I was so pissed, and didnt care about anything had rapid thoughts. Quote Link to comment Share on other sites More sharing options...
beataru Posted November 19, 2007 Share Posted November 19, 2007 At Idle? I dont think this is the spoiler, me thinks it is an exaust rattle or something else. Look at the base of the spoiler, where it mounts to the trunk lid, are there any scratches? Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 19, 2007 Share Posted November 19, 2007 Just my 2cents worth, but it sounds like your dealer isn't going to cover this under your warrantee anyways. That being the case, you can just fix it yourself. If it were mine, I'd get some rubber, like from an inner tube, and cut it to the size & shape of the spoiler mounts. Then bolt it between the spoiler & trunklid. This will damp any vibrations, and seal the spoiler to the trunk. If the noise continues after this fix, then I'd rule out the spoiler as the cause. Could your jack, or lug wrench be vibrating? Any non-stock items in there? Quote Link to comment Share on other sites More sharing options...
brus brother Posted November 19, 2007 Share Posted November 19, 2007 Just my 2cents worth, but it sounds like your dealer isn't going to cover this under your warrantee anyways. That being the case, you can just fix it yourself. If it were mine, I'd get some rubber, like from an inner tube, and cut it to the size & shape of the spoiler mounts. Then bolt it between the spoiler & trunklid. This will damp any vibrations, and seal the spoiler to the trunk. If the noise continues after this fix, then I'd rule out the spoiler as the cause. Could your jack, or lug wrench be vibrating? Any non-stock items in there? Exactly how I would proceed before running in circles, screaming and shouting. Quote Link to comment Share on other sites More sharing options...
beataru Posted November 19, 2007 Share Posted November 19, 2007 Exactly how I would proceed before running in circles, screaming and shouting. I wouldnt run in circles, I would do 4 wheel burnouts have you considered what I saied about the exhaust? Quote Link to comment Share on other sites More sharing options...
RallyKeith Posted November 20, 2007 Share Posted November 20, 2007 Has anyone considered adjusting the trunk latch? If the trunk is not latching tighly the entire trunk will vibrate... even at idle. Keith Quote Link to comment Share on other sites More sharing options...
nipper Posted November 20, 2007 Share Posted November 20, 2007 Has anyone inspected the exhaust system hangers? nipper Quote Link to comment Share on other sites More sharing options...
BlueTrain Posted November 20, 2007 Share Posted November 20, 2007 maybe those 2 12's in the trunk are vibrating the license plate. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 21, 2007 Share Posted November 21, 2007 maybe those 2 12's in the trunk are vibrating the license plate. no chance, the plate already fell off :-p nipper Quote Link to comment Share on other sites More sharing options...
chadwick35/04 Posted November 21, 2007 Author Share Posted November 21, 2007 Just my 2cents worth, but it sounds like your dealer isn't going to cover this under your warrantee anyways. That being the case, you can just fix it yourself. If it were mine, I'd get some rubber, like from an inner tube, and cut it to the size & shape of the spoiler mounts. Then bolt it between the spoiler & trunklid. This will damp any vibrations, and seal the spoiler to the trunk. If the noise continues after this fix, then I'd rule out the spoiler as the cause. Could your jack, or lug wrench be vibrating? Any non-stock items in there? Hi thanks for responding man! Yes the dealer is going to honor taking care of it, also since it was done this year under a parts warranty/body shop deal. I do indeed like your solution I was thinking about that witht he rubber, but being so cold out and no place to deal with it I dont know really where I could do it. My trunk is empty but I will check those items in there thats a good idea thanks man. Quote Link to comment Share on other sites More sharing options...
bansheercr Posted November 22, 2007 Share Posted November 22, 2007 Check the liscence plate for the rattle.I have a bezel around mine and everytime I close the trunk it rattles. Quote Link to comment Share on other sites More sharing options...
