subpilot Posted November 26, 2007 Share Posted November 26, 2007 I spent this morning searching the archives and probably missed it, but is it possible to rotate the compressor outlet on a TDO4 while maintaining the vertical inlet/outlet of the oil supply line? I know the waste gate diaphram won't work anymore but I intend to make this a manual control anyway. Thanks in advance, Subpilot Quote Link to comment Share on other sites More sharing options...
calebz Posted November 26, 2007 Share Posted November 26, 2007 I spent this morning searching the archives and probably missed it, but is it possible to rotate the compressor outlet on a TDO4 while maintaining the vertical inlet/outlet of the oil supply line? I know the waste gate diaphram won't work anymore but I intend to make this a manual control anyway.Thanks in advance, Subpilot I'll look into it. I have a dead TD04 in the garage. Quote Link to comment Share on other sites More sharing options...
subyrally Posted November 27, 2007 Share Posted November 27, 2007 you can, but then i think that the braket for the wastegate wont line up right with the holes in the compressor housing. i think thatwas the td04 i tried that on. i think its only like 6 bolts holding it in place,give it a try, worst case, you have to rotate it back and tighten it down. Quote Link to comment Share on other sites More sharing options...
daeron Posted November 27, 2007 Share Posted November 27, 2007 you are looking at "re clocking" the turbo housings. that might help you in your search. sorry, but thats all the help i've got Quote Link to comment Share on other sites More sharing options...
