axle #2 installed,another problem or not?
Well thanks to all the help from you guys I finally put a good axle in my 97 outback. After job was completed ,I pulled car outside and turning the wheel from one end of travel to the other(while stopped),I got a lot of noise from the front end. I had my wife turn the wheel while I looked and found the spring in the strut sticking on the top of the strut housing. I sprayed some lub.on top of spring and it seemd to quiet the noise. Does this mean the strut needs replaced or just a matter of a winter of road crap?
Thanks again for the help.
Collins
The strut AND spring assembly are supposed to turn as a unit, not independently of each other.
Either:
1) whoever assembled the strut did it wrong
or
2) the upper strut mount has expired.
