timing alignment help?
so i snapped a timing belt yesterday, and am having some real troubles getting the cams correctly aligned to the crank. i've been doing the routine of:
-distributor side cam pin straight up
-put the crank to the whatever degrees of the timing
-put that sides belt in
-turn the crank over once, so the cam opposite
-put the non-distributor side cam pin straight up
-put in the belt
no luck
please help, what am i doing wrong?
