mountainbikeak Posted April 27, 2008 Share Posted April 27, 2008 I have a 91 legacy that when I accelerate the shifter rattles. If I move the handle over just a bit it stops. Is a seal, rubber washer etc. possibly warm out? Any help would be much appreciated as the noise is getting old! Thanks Link to comment Share on other sites More sharing options...
EVOthis Posted April 27, 2008 Share Posted April 27, 2008 is there any play/looseness in the shifter itself......there a few possibilites...... 1)there is a little spring down there that connects the shift rod to the stay rod that may have broken in 2 and is still hanging on 2)not that it should cause a rattle but you may just need shifter bushings 3)if you have time i would get under there and check that all bolts/connections/motor and trans mounts are secure and not broken........ 4)also it could be something internal....but lets not jump to conclusions before you take a poke around....... Link to comment Share on other sites More sharing options...
