Spiffy Posted May 24, 2008 Share Posted May 24, 2008 I'm looking at replacing my y-pipe and wonder if any ea81 y-pipe will fit on my wagon... does it matter if it's from a brat or a hatch? will the length still be the same so that it meets the flange at the right place to the rest of the exhaust? mine has the little spacers off the heads that turn the flange 90 degrees, but I assume that it's optional depending on which one I get whether those flanges are pointing the correct way... --Spiffy Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 24, 2008 Share Posted May 24, 2008 No - some have spacers under only one head, and some have them under both. There are two or three styles depending on year/number of ASV's. The runners from the heads will be longer or shorter to compensate for the differences. GD Quote Link to comment Share on other sites More sharing options...
Spiffy Posted May 24, 2008 Author Share Posted May 24, 2008 I've already got 2 spacers (one on each side) so I shouldn't need to worry about that... I think... since if I got one that was longer to the heads I could just remove the spacers... I think the thing I'm most concerned with is the length back to the flange where it meets the next section of exhaust... mine is about 45" from flange to flange (not too exact since I measured it on the car)... what are ASV's? --Spiffy Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted May 24, 2008 Share Posted May 24, 2008 what are ASV's? air suction valve I have replaced the y pipe on my ea81 hatch with one off of a ea82 carb car. Fit on just fine. The only thing is that you will have to modify the hanger bracket to attach it to your car on the underside by the donut gasket. Quote Link to comment Share on other sites More sharing options...
monstaru Posted May 25, 2008 Share Posted May 25, 2008 some ea82 pipes are bigger and afford more blow room. (bigger on ze inzide)yah usually by about a quarter inch.cheers, brian Quote Link to comment Share on other sites More sharing options...
GLCraig Posted May 25, 2008 Share Posted May 25, 2008 Removing the spacers from the heads can be a royal P.I.N.T.A. Also the fange a the end of the Y-Pipe where it meet the mid pipe are not all the same either. 80 and 81 used a flat gasket between the pipe sections, 83+ use a donut and 82 used one or the other; I can't remember which. Quote Link to comment Share on other sites More sharing options...
SkankinPickle Posted May 25, 2008 Share Posted May 25, 2008 '82 uses the flat flange in the rear. 83+ uses the beveled/tapered end, which is spring loaded against the mid pipe to allow very slight 360* movement of the mid. Quote Link to comment Share on other sites More sharing options...
