cmiller Posted November 14, 2008 Share Posted November 14, 2008 Well this afternoon I start the swap process. I'm disconnecting and hopefully pulling the 5SPD S/R out of the Loyale by tonight. Then tomorrow put in the 5SPD D/R into it and road test. I will post pics as things roll along. here's the new transmission waiting to go in the Loyale. I put in new seals, new shift bushings, clutch bearing, dust boot, and tranny mounts. Can't wait to have it in!! Quote Link to comment Share on other sites More sharing options...
Quidam Posted November 14, 2008 Share Posted November 14, 2008 Hi, This very swap is in my near future. What year DR tranny are you using? I may use a '86 or an '89. Doug Quote Link to comment Share on other sites More sharing options...
cmiller Posted November 15, 2008 Author Share Posted November 15, 2008 Hi, This very swap is in my near future. What year DR tranny are you using? I may use a '86 or an '89. Doug I pulled mine out of a '88 GL from the wrecking yard. Its in great shape and the donor car has 80,000 less miles on it than my Loyale. Quote Link to comment Share on other sites More sharing options...
cmiller Posted November 15, 2008 Author Share Posted November 15, 2008 (edited) AND IT BEGINS! up on stands and front tires off. pulled the shifter and console out and moved the carpet out of the way. Next I'm disconnecting as much as I can on top of the tranny from under the hood. Then move the exhaust and drive line out of the way. More pics on the way! Edited November 15, 2008 by cmiller Quote Link to comment Share on other sites More sharing options...
cmiller Posted November 15, 2008 Author Share Posted November 15, 2008 Pulled off the skid plate and dropped the exhaust off of the block... Rear hanger bushings came off easy... But this one is stubborn, it won't budge... Quote Link to comment Share on other sites More sharing options...
monstaru Posted November 15, 2008 Share Posted November 15, 2008 (edited) big screwdriver through same hole as hanger,place flathead of screwdriver behind hanger end and pry off...........:Dcheers,brian Edited November 15, 2008 by monstaru Quote Link to comment Share on other sites More sharing options...
cmiller Posted November 15, 2008 Author Share Posted November 15, 2008 Pile of parts, drive shaft, skid plate, exhaust, etc... Everything disconnected from the transmission, driveline, front axels, etc... Now ready to drop the transmission, but I think its time to call it a night. Quick question, what are people doing with the two extra vacuum lines from the push button 4WD after they are disconnected? Don't really need them with the new transmission. Quote Link to comment Share on other sites More sharing options...
cmiller Posted November 15, 2008 Author Share Posted November 15, 2008 (edited) Well, back at it again. Should go quicker today with my buddy helping out. Thanks for the tip Brian, it took some work to pop it off the hook. Edited November 15, 2008 by cmiller Quote Link to comment Share on other sites More sharing options...
cmiller Posted November 16, 2008 Author Share Posted November 16, 2008 Old transmission out... ready for the dual range putting in the dual range shift linkage and interior all buttoned up. Everything went in easy and without a hitch. I just plugged up the vacuum lines from the old tranny, also I kept the Loyale shifter with the button. I dunno what to hook up to the switch. Any ideas? passenger ejector seat? air horn?... Did the road test and man what a difference in 4 low! Can't wait for some snow! Quote Link to comment Share on other sites More sharing options...
Snowman Posted November 16, 2008 Share Posted November 16, 2008 You should make one of those things that shoots flames out the tailpipe. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 16, 2008 Share Posted November 16, 2008 Congrats on completing project!!! Have fun! Quote Link to comment Share on other sites More sharing options...
scoobyclimbs Posted November 17, 2008 Share Posted November 17, 2008 (edited) nice work:drunk: Hows this Sunday for wheelin ... Team CF and I are always out and about...let's go wheelin' ! Don't forget the HP X-mas tree run..! I need to do the swap myself as my 4spd has a bad 3rd gear syncro and no hi range.. For the switch I would make it the turbo boost(Blower) switch ya know like the madmax intercepter...lol Edited November 17, 2008 by scoobyclimbs Quote Link to comment Share on other sites More sharing options...
Quidam Posted November 17, 2008 Share Posted November 17, 2008 "Any ideas?" Well, duh. jk:) Nitrous Oxide. Quote Link to comment Share on other sites More sharing options...
cmiller Posted November 17, 2008 Author Share Posted November 17, 2008 nice work:drunk: Hows this Sunday for wheelin ... Team CF and I are always out and about...let's go wheelin' ! Don't forget the HP X-mas tree run..! I need to do the swap myself as my 4spd has a bad 3rd gear syncro and no hi range.. For the switch I would make it the turbo boost(Blower) switch ya know like the madmax intercepter...lol Nice! I have to work this weekend. But I really want to see your new hatch. The tranny swap was much needed. Next I have to figure out a front bumper. Quote Link to comment Share on other sites More sharing options...
ChuckPT Posted November 20, 2008 Share Posted November 20, 2008 So I have an '85 with the POS 3 speed auto so I need a swap of this kind. I am curious if anyone knows about the peddle assembly and if any cutting of the firewall would be needed to fit a clutch peddle? Thanks for any input available and congrats on the upgrade.. Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 20, 2008 Share Posted November 20, 2008 So I have an '85 with the POS 3 speed auto so I need a swap of this kind. I am curious if anyone knows about the peddle assembly and if any cutting of the firewall would be needed to fit a clutch peddle? Thanks for any input available and congrats on the upgrade.. No cutting necessary. Just make sure you get all the parts needed for the swap. Peddle assembly, clutch cable. Complete running gear. Make sure the rear diff ratio you get matches the tranny (3.9 for a 5spd D/R non turbo) Quote Link to comment Share on other sites More sharing options...
bratman18 Posted November 20, 2008 Share Posted November 20, 2008 No cutting necessary.Just make sure you get all the parts needed for the swap. Peddle assembly, clutch cable. Complete running gear. Make sure the rear diff ratio you get matches the tranny (3.9 for a 5spd D/R non turbo) I did this swap as well and changed the whole dash board and harness as well and I also stole the manual seat belts out of the donor car as well! Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted March 17, 2009 Share Posted March 17, 2009 will an 83 - 87 dual range trans bolt right into a 91 loyale 5 spd?? i have dreams... thanks, john Quote Link to comment Share on other sites More sharing options...
bratman18 Posted March 17, 2009 Share Posted March 17, 2009 will an 83 - 87 dual range trans bolt right into a 91 loyale 5 spd?? i have dreams... thanks, john It would with some mod, but are you talking about the 4 spd d/r? If so it's not worth it, the 5 spd is much stronger Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted March 18, 2009 Share Posted March 18, 2009 (edited) It would with some mod, but are you talking about the 4 spd d/r? If so it's not worth it, the 5 spd is much stronger yes the 4 spd d/r, 83 - 87, i was just looking for the low range, off road. how different are they? the gear ratios appear to be close. is the loyale too heavy? mostly i was wondering about the bell housing bolts. what kind of mods besides the hi low lever, trans mount, shifter? is it possible/ practical to swap the 'dual range' section on to the loyale 5 speed?? Edited March 18, 2009 by johnceggleston Quote Link to comment Share on other sites More sharing options...
bratman18 Posted March 18, 2009 Share Posted March 18, 2009 You would probably need the drive shaft that went with the 4spd. The tranny itself is a lot longer than the 5 spd. And the lo range isn't as low as the 5 spd Quote Link to comment Share on other sites More sharing options...
