Scott in Bellingham Posted November 23, 2008 Share Posted November 23, 2008 Heres my car a built 1-1/2 years ago, In starting to work on it again, so I thought I would start a thread, heres the specs, 87 Turbo wagon 118,000 miles EJ 2.2 EFI stock Subaru 5 speed Bronco 2 4 speed with transfercase 3.90 welded rear diff 3.90 open front diff 31 x10.50 tires body shortned 20" just put in the EJ still have to wire it up plan on taking it to Walker next time out as the white car is brocken, Quote Link to comment Share on other sites More sharing options...
monstaru Posted November 23, 2008 Share Posted November 23, 2008 did you cast a new bellhousing or just cjhop out for the starter and add an adapter plate?doh!! just reread....howd you do the tranny and transfer case piggybacking the 5 spd.....?cheers, brian Quote Link to comment Share on other sites More sharing options...
one eye Posted November 23, 2008 Share Posted November 23, 2008 So your in for the next run? Dec. 13/14th? Jeff Quote Link to comment Share on other sites More sharing options...
bigo1966 Posted November 23, 2008 Share Posted November 23, 2008 You need to list your crawl ratio. Now thats cool:headbang: Quote Link to comment Share on other sites More sharing options...
monstaru Posted December 1, 2008 Share Posted December 1, 2008 right scott, what is your ratio?cheers, brain Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 1, 2008 Author Share Posted December 1, 2008 right scott, what is your ratio?cheers, brain OK this is the specs Stock turbo trans 1st gear no low range 3.54 Bronco 2 first gear ............... ........... 3.96 Bronco 2 transfercase low range ......... 2.48 Subaru rear diffs front and rear .......... 3.90 ................crawl ratio............ .. 135.58 to 1 stock subbie 5 speed with dual range for comparrison 1st gear ........3.54 low range...... 1.6 diffs............. 3.9 crawl ratio.... 22.08 to 1 Quote Link to comment Share on other sites More sharing options...
one eye Posted December 2, 2008 Share Posted December 2, 2008 Crawl. That's good, Jeff Quote Link to comment Share on other sites More sharing options...
Rooinater Posted December 2, 2008 Share Posted December 2, 2008 OK this is the specs Stock turbo trans 1st gear no low range 3.54 Bronco 2 first gear ............... ........... 3.96 Bronco 2 transfercase low range ......... 2.48 Subaru rear diffs front and rear .......... 3.90 ................crawl ratio............ .. 135.58 to 1 stock subbie 5 speed with dual range for comparrison 1st gear ........3.54 low range...... 1.6 diffs............. 3.9 crawl ratio.... 22.08 to 1 ping! those subaru diffs and axles are going to need to go... 55:1 to 60:1 is enough torque to shear the stub shafts and cv cups. how many inches is the rear driveline???? Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted December 2, 2008 Share Posted December 2, 2008 That is a pretty sweet rig ya got there for sure! -Bill Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 2, 2008 Author Share Posted December 2, 2008 ping! those subaru diffs and axles are going to need to go... 55:1 to 60:1 is enough torque to shear the stub shafts and cv cups. how many inches is the rear driveline???? driveline 10" CV cups all ea82 , tires not that big Quote Link to comment Share on other sites More sharing options...
one eye Posted December 2, 2008 Share Posted December 2, 2008 I've gone wheeling with Scott and this rig before, he's never had any trouble, meanwhile I broke the whole rear of the Brat off and everysingle axle. But his just keeps crawling. Scott you got 30's on that? Jeff Quote Link to comment Share on other sites More sharing options...
Rooinater Posted December 2, 2008 Share Posted December 2, 2008 maybe when I get the new diff welded i'll have to swap in some ea82 cups.... Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 2, 2008 Author Share Posted December 2, 2008 all this talk of what works what doesnt its all from a good source, but driving technique is a big part of if you break or not , all the stuff I have broke could have been prevented if the driver (me) had driven differently Ive bent radius rods, destroyed a clutch ,broke a stub shaft on a rock smacking it, lost reverse ,all because of how I drove, Ive watched many videos of machines offroad breaking all sorts of parts and its usually the drivers technique or a systen set up improperly like overextending a cv Quote Link to comment Share on other sites More sharing options...
Rooinater Posted December 2, 2008 Share Posted December 2, 2008 all this talk of what works what doesnt its all from a good source, but driving technique is a big part of if you break or not , all the stuff I have broke could have been prevented if the driver (me) had driven differently Ive bent radius rods, destroyed a clutch ,broke a stub shaft on a rock smacking it, lost reverse ,all because of how I drove, Ive watched many videos of machines offroad breaking all sorts of parts and its usually the drivers technique or a systen set up improperly like overextending a cv well, i have a seriously limited rear suspension, so no over extended shafts here. i'm not heavy on the pedal, i prefer to crawl along and use minimal go pedal, which is one of the many reasons i'm not a mudding fan. i've never broke the stub or cv by hitting it on a rock. It usually breaks when the shafts get bound up, add extra torque via gearing and a worked up 1.8L and a very small touch of gas or when it goes from no traction to instant traction and shears the stub. it's generally the stub, hence why i carry 4 - 6 spares on every trail run. I believe all the pavement runs to and from the trail on rwd and a lincoln locker is causing a lot of the stress on the rear cv's and stub axles, which is why i'll be starting to pull cv shafts again when i start back to wheeling her. Quote Link to comment Share on other sites More sharing options...
one eye Posted December 3, 2008 Share Posted December 3, 2008 (edited) That last run where I took my Brat up. I know that it doesn't matter how you wheel, since Will, Rob, Woody, and me All broke one or more axle(s), all said and done one day of wheeling broke or better yet they "Shattered the Bells, 6 axles, on 4 different cars, and all of them where EA81, since most all of us have given up on Wheeling EA81, and converted to EA82's There has only been one rear axle broke on 7 or 8 trips. GD has a good write up on the EA82 bells on EA81 axles. They are a crap load stronger. Jeff Edited December 3, 2008 by one eye Quote Link to comment Share on other sites More sharing options...
