bicycle_ben Posted December 10, 2008 Share Posted December 10, 2008 so im brand new to this whole owning a car thing! i just bought my dream car, an 81 GL wagon but up till a week ago ive only owned a motorcycle and the choice for tires was easy. now that i have 4 awsome little 13" wheels with 4 different little mis matched tires i want to find something as off roadie as possible to put on them. right now im looking at a set of these guys: 175/70R13 Firestone Winterforce if anyone has suggestions for tires id be happy to listen! Quote Link to comment Share on other sites More sharing options...
86HatchShelby Posted December 10, 2008 Share Posted December 10, 2008 Planning on staying 13"? I have Toyo 800's, kinda gay little tire, no exciting tread, but do great in the snow and have 100,000 mile warranty, and with a welded rear diff... -Jaren Quote Link to comment Share on other sites More sharing options...
bicycle_ben Posted December 10, 2008 Author Share Posted December 10, 2008 mmmm welded rear dif - thats going to happen right after i weld my self up a set of bumpers and a roof rack - yeah im trying to get away from the little stock looking tires if i can Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 10, 2008 Share Posted December 10, 2008 Find some puegeot wheels. They are bigger and therefore you can fit a better option of tires. Quote Link to comment Share on other sites More sharing options...
86HatchShelby Posted December 10, 2008 Share Posted December 10, 2008 Or hub redrill, or rim redrill My tires are stock size, but the sidewall is taller, so they are bigger looking. -Jaren Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted December 10, 2008 Share Posted December 10, 2008 I have a set of 185 65 15 and they are great, even better with LSD went out today after 6" of powdery snow, lots of fun, testing tires, learning how everything reacts, going up and down steep hills and slamming on the brakes -- it slides straight, just practicing lsd will be in soon day before, went on crappy rutted class b roads '86 gl-10 t-wag ea81 Quote Link to comment Share on other sites More sharing options...
Turbone Posted December 10, 2008 Share Posted December 10, 2008 I have a set of 185 65 15 and they are great, even better with LSD went out today after 6" of powdery snow, lots of fun, testing tires, learning how everything reacts, going up and down steep hills and slamming on the brakes -- it slides straight, just practicing lsd will be in soon day before, went on crappy rutted class b roads '86 gl-10 t-wag ea81 Wat? Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted December 10, 2008 Share Posted December 10, 2008 Wat? 'tis just Wat it says it is '86 gl-10 t-wag ea81 transplanted ea81 engine, with ea82 carb and intake, swapped injection pump for carb pump, removed fuel sending unit and ran new hose for suction under the carpet, even made a plate from aluminum sheet, drilled a hole in the center, added grommet to run fuel pickup through, because fuel tank bottom is covered in sludge, and standard pickup is plugged, fuel pump controlled by standard system, no re-wiring required more details available upon request Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted December 10, 2008 Share Posted December 10, 2008 i seen it, it is now a carbed ea81 86gl-10 turbo wagon. the old ea82turbo motor is pulled out...pretty sweet. 'tis just Wat it says it is '86 gl-10 t-wag ea81 transplanted ea81 engine, with ea82 carb and intake, swapped injection pump for carb pump, removed fuel sending unit and ran new hose for suction under the carpet, even made a plate from aluminum sheet, drilled a hole in the center, added grommet to run fuel pickup through, because fuel tank bottom is covered in sludge, and standard pickup is plugged, fuel pump controlled by standard system, no re-wiring required more details available upon request Quote Link to comment Share on other sites More sharing options...
one eye Posted December 10, 2008 Share Posted December 10, 2008 If you stay with 13" tires, 185/80/13 Wintertrax are pretty good. Jeff Quote Link to comment Share on other sites More sharing options...
