My 1986 Brat
Well my neighbor had this sitting around, so I asked him what he wanted for it and gave him a $150! It had sat for a year and a half, but after a new battery and a little bit of priming it fired right up and ran like a top! I do not plan on keep this long cause it is kind of beat up, (I want an RX, anyone want to trade? Also have an 87 wagon I'd give for an RX) I kind of just want to make it work better and sell. Bring an old Soob back to life so to speak.
Now for the help I will most likely need:
I had to put it in 4wd to get anywhere, and he said it needs new front CV joints. I got it to my house and then went home for the holidays and have not seen it since (I'm a student at U of Idaho, but am from Portland). He said that it may be the CV joint just needs pushed back in. I do all my own work, but am a 'go by the manual' mechanic, so to speak. So any idea what he means by 'push it back in?' I like to pick up these old soobs and just work on them and learn what I can, just have never done these before.
I believe it also needs a new ignition as it is so near impossible to get the key to turn. It locks up somehow.
But without giving a basic tuneup these are the only two things I was able to find that is keeping this brat from being a great running vehicle.
Here is a pic of my wagon (since painted the wheels flat black, which surprisingly makes it look a lot better) that I got in August for just $200! Which makes the total cost of these cars just $350; I like getting deals! :)
And below is the Brat. PM if there is any initial interest (on either vehicle). I would like to get at least $500 for it eventually, or an RX!
GetAttachment.aspx?tnail=0&messageId=af617aa5-2e43-4ad0-ad8c-afe7aafaf7a8&Aux=4%7C0%7C8CB3F365D04DBB0%7CGetAttachment.aspx?tnail=0&messageId=4d9115fb-2364-4280-a922-e3eb8fd1a696&Aux=4%7C0%7C8CB3F35318B8390%7C
great to see someone else reviving old soobs. i am close to you, in Clarkston, i have only been into soobs for a couple of years but they are pretty simple, i may be coming though on the weekend, not sure what you need done but may be able to work something out or at least take a look.
intrested, post some pictures and ill let you know
Hey I think I'm gonna head on back this weekend, cause right now I'm still in Portland. I will get more pictures then and post them on this thread. If I get it running well and looking better we might even be able to meet halfway and trade that lifted wagon you have for this thing! (just a thought)
I dont think I will be able to get anything done this weekend, but with you being so close we should definitely look into getting something together. What is it youre driving?
na im putting a EJ22 into my lifted wagon right now, as well as just finished my custom rear bumper. im keeping it, but wouldn't mind a brat, trying to find a GEN1 mostly though.
I have that blue 87' twin of your wagon and I found a guy who sells lifts for them down here in my hometown of Scappoose, OR for around $400, so thats an option for me too. I'm just unsure of dumping money into that wagon right now with the carb that it has on it, has some issues with the choke.
If you need to put it in 4WD to get it to move, check and tighten the castle nuts on both front wheels. If it still doesn't move in FWD, then one or both of the front hubs are stripped and need replacing.
Also, check the inner and outer axle boots. If one is pretty torn up, it could be a broken joint which could give you the same symptom as a stripped hub.
Good luck with it. Nice score.
I dont know what happened to the pictures in the original post....but yes the Brat is beat up. Here is its good side:
GetAttachment.aspx?tnail=0&messageId=4d9115fb-2364-4280-a922-e3eb8fd1a696&Aux=44%7C0%7C8CB3F35318B8390%7C
More pictures to come possibly by this weekend. This is just the only one I took before I left town for the holidays.
I will check the castle nuts when I get back, but something I forgot to bring up before is that when the car is not moving that whole thing was spinning. The wheel was still, but the nut was spinning. Thats when he said it might need to be just pushed back in.
