GR86BRAT Posted January 18, 2009 Share Posted January 18, 2009 I'm thinking about 4" 's would do the trick. Does PK/BYB still exist? Ozified? Any other good lift kits and website info would be greatfully appreciated. I'm not having much luck in my searches. With a 4" lift what is the biggest tire setup I could use without cutting The fenders? BTW, I do plan on the 6 lug conversion so I can tap into the 15" Wheel market. Will I have any mods with a 4" lift? Driveshaft, steering rod etc? Thanks Btw I live in TX. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 18, 2009 Share Posted January 18, 2009 Yeah your right. This is a pretty tough subject. I can understand how your searches would fail... we hardly ever talk about any of this anymore Maybe we should create some sort of off-road forum for questions specifically like this one. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted January 18, 2009 Share Posted January 18, 2009 (edited) I'm thinking about 4" 's would do the trick. Does PK/BYB still exist?Ozified? Any other good lift kits and website info would be greatfully appreciated. I'm not having much luck in my searches. With a 4" lift what is the biggest tire setup I could use without cutting The fenders? BTW, I do plan on the 6 lug conversion so I can tap into the 15" Wheel market. Will I have any mods with a 4" lift? Driveshaft, steering rod etc? Thanks Btw I live in TX. First of all you should post this in the off road section. Second, check out sjrlift.com He does some nice lift kits etc. There are a few others as well. PK/BYB doesn't do lifts anymore. And lets see some pictures of your Brat! Edited January 18, 2009 by bratman18 Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted January 18, 2009 Share Posted January 18, 2009 I agree. www.sjrlift.com is a great source for a very good looking lift. I don't think he provides extended brake lines and steering linkage. Those are pretty much the only things you'll need including the lift. Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 19, 2009 Share Posted January 19, 2009 with four inches it is not completely necessary to get brake line extensions....i have removed them from the "mounts" and never had any problems. the steering extension is simple.if you have any common sense at all it should be easy.cheers, brain Quote Link to comment Share on other sites More sharing options...
GR86BRAT Posted January 19, 2009 Author Share Posted January 19, 2009 Thanks to all for the invaluable info. I did find on one site that with a 4" lift you could mount use 27"x8.5" wheels...!? Sounds promising. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted January 19, 2009 Share Posted January 19, 2009 I know that you can sqeeze up to 31" tires under a 4" lift, its just about how much cutting/bashing you want to do and how much tire rub you are comfortable with. With a 6" lift, you dont need to cut anything to clear 27" tires. With a 4" there will be a little rubbing unless you do some minor trimming and beating. -Bill Quote Link to comment Share on other sites More sharing options...
RdNkBrt Posted January 20, 2009 Share Posted January 20, 2009 contact 4x4brat.... he'll build you a nice lift Quote Link to comment Share on other sites More sharing options...
