Guest wrxsubaru Posted June 26, 2003 Share Posted June 26, 2003 Right now i went to pick up a 92 svx. The owner replaced the battery because the old one died and would not take a charge. The new one battery worked once, the night before, but now the battery takes a charge, but the car does not get any power at all. Is there any fuse that could cause this?? Any ideas THANKS please resond as fast as you can becuase we have to get this car running so I can drive it 800 miles home. Quote Link to comment Share on other sites More sharing options...
Guest brattysvx Posted June 26, 2003 Share Posted June 26, 2003 So you are saying nothing works right? No power to the lights, radio, etc? Check the cable connection on the battery and fusable links. Quote Link to comment Share on other sites More sharing options...
Guest sirveaux Posted June 26, 2003 Share Posted June 26, 2003 Try jiggling the battery cable connections on the battery posts. When I put a new battery in, I got the negative one on too loose, and occasionally it would arc and short out or something, I really don't understand what was happening, but a little jiggle fixed it. Something to try -Ryan Quote Link to comment Share on other sites More sharing options...
Guest camosuba Posted June 26, 2003 Share Posted June 26, 2003 so did you get it home yet? Quote Link to comment Share on other sites More sharing options...
Guest wrxsubaru Posted June 27, 2003 Share Posted June 27, 2003 it was the fusable link. We got the car home today, about 900 miles. The tranny held, and isn't sliping, or any thing. The tranny did have a leak but we put some stop leak stuff in it and it completlty stopped. Quote Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted June 27, 2003 Share Posted June 27, 2003 you probably also gummed up all the passageways in your transmission by putting that stop leak in it. I highly suggest you change that fluid and hope it flushes that stop leak out. Are you planning on rebuilding the tranny? Quote Link to comment Share on other sites More sharing options...
Guest wrxsubaru Posted June 27, 2003 Share Posted June 27, 2003 The stuff i put into the tranny was not a thick or guey, it frlt like regular ATF, its spose to make all the seals expand, to stop the leak. I would want to rebuild the trannie, but the reason it broke was she put it into reverse when she was moving a couple times, she said the trannie guy pulled bolts out of the pan, when she took it in to get looked at. I think some mounting bracket got torn out of the tranny or something. any ideas? Quote Link to comment Share on other sites More sharing options...
