went for a test drive after all the work i have done to my 95 subaru. replaced the right front cv axle but still clicks and clunks with acceleration and turning.
passenger says it feels like it is right at his feet. when install ing the axle i pulled the splines out inside the axle in the boot but it went back together fine. is this the problem. def sounds like drive axle but it is a brand new axle.....
AHHHHHHH!
you installed the spring pin?
axle nut is REALLY tight?
no, there is no break in period for an axle.
don't want to jump the gun and trash a good axle but there's a good chance the axle is junk because you bought an after market axle, right? spend some time reading here and you'll find after market axles suck. after having my own expeditions with aftermarket axles i now only use Subaru or MWE axles. i recommend you doing the same if it turns out this axle is bad.
