titikaka Posted June 19, 2009 Share Posted June 19, 2009 Hi all, I bought a Suburu EA-71 engine in order to replace a Rotax in a ultra light airplane ( ballerit HM 1000) The ignition coil was missing, I bought one from another subaru vendor. The problem is that there is no spark at the ignition coil output. I maybe made a wrong connection but I don't find any wiring diagram. My hall sensor has to wires : yellow and Black/white. Ignition coil has to pi : + and - I have connected Sensor: sensor yellow <--> battery + sensor black&white <-> coil + coil - <---> ground = battery - I am wondering now if there is any control unit between coil and sensor.. Does anybody can help ?? Thanks a lot if any idea I will bought a repairing manual but not sure to find this diagram inside... Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted June 20, 2009 Share Posted June 20, 2009 The negative side of the coil is switched. Connect the positive side of the coil to the ignition switch, and the negative side to the distributor. Quote Link to comment Share on other sites More sharing options...
titikaka Posted June 20, 2009 Author Share Posted June 20, 2009 Thanks a lot! Hope the engine will start now..! I discovered pinout connections of the sensor/ignition module : but they are exactly inverted...an idea of the good one ? http://www.mobiletron.com.tw/detail_main.asp?ID=978 http://www.nbhuaao.com/en/proview.asp?P_ID=1022 It seems also that we can find the same module in Honda civic 1300 from 1980 to 1983 http://www.hondapartsnow.com/Page_Product/PartDetail.aspx?catalogID=22&productID=4&yearID=13&doorID=2&gradeID=56&areaID=3&transmissionID=3&originID=-1&colorLabelIDs=-1&colorLabelID=-1§ionID=1&idAndImageID=3844%20457257&refNo=12&isBigPicture=False&pageName=&appid=4190 And I guess in other car : Nissan but don't know which one .. GM:94243344 HITACHI:E1261 HONDA:30120-PA0-661,30120-PH4-005 32120-PA0-661 NISSAN:22020-15M00,22020-15M20 ISUZU:8-94243-344-0 LUCAS:DAJ106 SUBARU:49146-7401 Thanks a lot Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 20, 2009 Share Posted June 20, 2009 You should have power on the blk/wht wire, if not check your fuses. This comes from the ignition switch and ties to the plus side of the coil. The yellow wire goes to the angle sensor and ties to the minus side of the coil. Quote Link to comment Share on other sites More sharing options...
titikaka Posted June 20, 2009 Author Share Posted June 20, 2009 Cougar, you are perfectly right Cougar! I did exactly the reverse connection... Following your information : now it is working perfectly : almost 2 cm spark turning slowly delco by hand! Just have to put back in the engine and it should start!! So here is what I did to make it work : 1) This is the Sensor/Ignition Module with 2 pins : Coil (yellow), +12v (black/white) ------ / | | |_____ | Coil ) | O ) | + _____) \ | \ | ------- I connect Coil (yellow) to Minus (-) of ignition coil I connect + of sensor (black/white) to +12v I connect + of ignition coil to +12v Its seems so easy now, but I didn't even know if a intermediate module was missing or not since I got the engine without the car So http://www.mobiletron.com.tw/detail_main.asp?ID=978 is wrong for me but http://www.nbhuaao.com/en/proview.asp?P_ID=1022 is ok In order to help people with broken ignition module (but it seems to be very strong since I made reverse connection and bad wiring, and still alive now!) Following the last url : the list of cars with such a module : GM AstraLB 1.5 1984-1986 AstraLC 1.6 1986-1987 GMTRUCKS 1982-1985 Others1.9L Eng. S10, S15 1982-1985 HONDA Accord2 1986-1987 AccordEFI 2.0 1987-1989 Prelude1.6 Coupe 1979-1982 Prelude1.8 Coupe 1983-1984 Quintet1.6 1981-1982 ISUZU OthersPick-up 2.3L (4 ZDI) Eng. 1986-1987 TrooperMKII 2.3 1986-1987 NISSAN 3101.5 (E 15 Eng.) 1981-1982 PrairieM10 1.5 1985-ON Pulsar1.5 1983-1986 Sentra1.5, 1.6 1982-1983 SunnyFWD 1.3, 1.5 (B11) 1984-1986 SUBARU BratA.T. 1984-1985 Brat Dist.NO.429878900 1985-1988 Subaru1.8L Eng. 4 W.D. 1981-1986 Subaru1.8L Eng. AT 1984-1988 A list of ignition module equivalent : 22020-15M00 22020-15M20 22020-P4005 30120-PAO-661 30120-PH0-661 30120-PH4-005 49146--7401 8942433440 94243344 2 vendors : http://www.lott.de/product_info.php/products_id/82098/ktnr/7679 And finaly an explode view of a similar (almost 100% identical to Hitachi subaru model) : http://www.hondapartsnow.com/civic/30120-PH4-005~ca13sa00~2.html (click on "component" to get the detailed view) Thanks 4x4_Welder's, thanks Cougar you can not imagine the time spent to find this information on the web! Regards from France :) Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 21, 2009 Share Posted June 21, 2009 Glad to hear you got it going and you're welcome for the help. Quote Link to comment Share on other sites More sharing options...
