coupe Posted July 13, 2009 Share Posted July 13, 2009 Hi Gang I have a turbo 89 with a blown motor, i was going to put a mpfi 89 engine in it to tie over while i rebuild the turbo engine. Will i need to swap the turbo ecu or will it run the mpfi ok. Cheers Pete Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 13, 2009 Share Posted July 13, 2009 The Turbo ECU will runt he NA motor fine. I have a hybrid EA82 in my car right now. EA82T block SPFI pistons (9.5:1) NA Spider intake Running great using the Original Turbo ECU and MAF There is sometimes a slight lag in throttle response at low RPMs, but overall it runs great. Quote Link to comment Share on other sites More sharing options...
coupe Posted July 18, 2009 Author Share Posted July 18, 2009 Thanks for the answer . it gives me options Cheers Pete Quote Link to comment Share on other sites More sharing options...
