suby85 Posted July 20, 2009 Share Posted July 20, 2009 Will the gage cluster out of an 88 XT6 work in a 94 Loyale. The XT6 cluster speedo goes to 140mph and the loyale goes to 130 and the XT6 cluster has the volt and oil pressure gages and the loyel doesn't. other than that, they look the same. the reason I am asking, is my loyale speedy does not work, and the XT6 does. Quote Link to comment Share on other sites More sharing options...
Turbone Posted July 20, 2009 Share Posted July 20, 2009 Will the gage cluster out of an 88 XT6 work in a 94 Loyale. The XT6 cluster speedo goes to 140mph and the loyale goes to 130 and the XT6 cluster has the volt and oil pressure gages and the loyel doesn't. other than that, they look the same. the reason I am asking, is my loyale speedy does not work, and the XT6 does. Umm, dont think so. They are quite different and may even have different harness's. Quote Link to comment Share on other sites More sharing options...
suby85 Posted July 20, 2009 Author Share Posted July 20, 2009 Thats what I thought, but had to ask sence I had the XT6 half parted out and the gage cluster was just sitting there. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted July 20, 2009 Share Posted July 20, 2009 even if you could get them to work the tach would likely be off because of the different number of cylinders. If you want more guages get a GL dash cluster from 85-89 Quote Link to comment Share on other sites More sharing options...
suby85 Posted July 21, 2009 Author Share Posted July 21, 2009 Successful at last…used the Speedo internals from the XT6 with the Speedo gears from the Loyale. Works great, no more bounce in the Speedo. I even kept the original odometer. Quote Link to comment Share on other sites More sharing options...
