junkyardgabe Posted January 29, 2004 Share Posted January 29, 2004 are the hubs strong enough so that if you grind down the hub to properly seat the lugs on a 6 lug conv. that they won't crack or should i weld up the low spots and drill the hubs that way? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 29, 2004 Share Posted January 29, 2004 You don't have to grind them at all. They will still pull up fine once you tighten them down. And unless your doing it for mags, drilling the rims is definately easier. Many, many people are running drilled rims, and put them through hell. I've never heard of one breaking, except from improper installation. GD Quote Link to comment Share on other sites More sharing options...
Rossta86 Posted January 29, 2004 Share Posted January 29, 2004 The way i did my 6 lug conversion was I frist drilled the hubs with a 9/16 bit? I think that was it. I had too grind down some of the sides of the studs to make them fit better. Then i actually ran it for atleast 500 miles with studs loose in the drilled holes. It does fine aslong as the lugs are tight. Once i got my welder and be came comfortable with it, i pulled my hubs off, bolted them to the wheel, then filled in the low spots and put a bead around the studs. One can argue which is better (drilling the hub or rim), but im just stating that this way worked fine. I probably would have drilled the rims, except the style of yota wheels i got could not be drilled right. I don't think i would try to grind the hub itself down, just because the metal is pretty hard. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 29, 2004 Share Posted January 29, 2004 my example was to use chevy 6 lug rims, like on 1/2 ton 140mmx6 what i did was use a soob hub, pop out 2 opposite studs, and then bult it to the rim. then i used the hub to drill through the rim, and i uses 21mm lug nuts, that still have the subaru m12 1.25 thread, and 60 deg seat. i had to grind away the center of the rim to fit the hub there are other rims that will work, toyotas and such. im sure someoner can tell you about those. but i say use a rim that is suitable to drill through, if you go that route http://www.warpthree.com/milesfox/88sedan/cwdata/88sedanwheel.html http://www.warpthree.com/milesfox/87rx/cwdata/RXDoorsOpen.html Quote Link to comment Share on other sites More sharing options...
