How tight
My newly brakes are working good but i noticed some squeeking and popping on one of the sides. I can wiggle the wheel around alittle. When i pop off the wheel the castle nut is on but i can wiggle it back and forth. Seems the cotter pin is holding it onto the hub mostly. How tight does this need to be
no i recently put on rear disc brakes so i had all that mess apart. Its not squeeking though or rattling. Ill get it tightened on more and yet you know if that was the problem. Its not a constant squeek or rattle i should say. Just sounds like something is loose. Yea it definately doesnt have 150 lbs or torque to it.
