Red Sedan Build , solid rear axle
Scott in Bellingham
I've talked to the guy that has the John Deere Brat from WCSS10.
He's doing a Zuki case and cut the tunnel to clear it with the trans in the stock location.
Says the sheetmetal surrounding it will make a nice arm rest. And it's tucked up in with the body. Nothing hanging down. :)
mine is all protected like that too, but I wouldn't think the sheetmetal inside would be tall enough for an armrest? but could be different for a gen1, and if he clocks it or not....
  • Replies 249
  • Created
  • Last Reply
Top Posters In This Topic
got the taco rear home, need to find a driveline next checked all the ones I have none fit
you'll need to get a Toy rear driveshaft (very strong) and have it made to the corret length, with either a Nissan flange, or an adapter to go from the toy flange to the nissan flange. my front shaft is made with a soob front yoke, and the back has a sammy flange and u-joint.
God! Wonder how that feels when going only 25mph! its got to cause alot of vibration, Kinda sucks you'd need to trailer your rig to the wheeling area insted of driving it there.
But that is a nice soild shaft, no need to worrie on breaking those yokes!
-Tom
Is this the new Aquafina 8" lift prototype?? :lol:
This thing is going to look awesome!! Are you going to link it in the rear, or just go with some springs and call it good? Since you have IFS still, i would look into doing a 4 link rear end, the suspension will cost more, but you're articulation will thank you for it.
you only really want like 5 or 6 inches of uptravel anyway.so , i bet if the shocks , at a bottomed out position, also triangulated would accomplish being able to keep those tires up in there, but the pumpkin off of the gas tank
you will probably have a hell of a rake......:lol:
cheers, brian
  • 2 months later...
it time to get back on this heres the planned revised specs
4.10 toyota rear end
4.10 subaru rear diff upfront
31" mudders would like to get some 32 x 9.50 TLS Swampers eventually, will wait till its runnin
dual transfercases, stock subaru and Nissan 720
bob the rear pinch the front
winch mounts front and rear
transverse buggy spring in rear with tons of flex with airshock overrides
engine not sure may go EA81 or carbed EJ or Atomic flux capacitor
would like to have it up and going for this summer season of Walker wheelin
