bheinen74 Posted June 23, 2011 Share Posted June 23, 2011 (edited) 1 Edited June 23, 2011 by bheinen74 Quote Link to comment Share on other sites More sharing options...
bratclay Posted June 23, 2011 Share Posted June 23, 2011 Drove my subi boot looks like someone got mad and sliced it with a knife. I go threw those like flipen candy.lol..... and I'm just learning how to use usmb so bare with me if I post stuff in the wrong arias. Still usin the bfs profile Quote Link to comment Share on other sites More sharing options...
987687 Posted June 23, 2011 Share Posted June 23, 2011 I put LEDs in mine too, sorry no night time shot... Quote Link to comment Share on other sites More sharing options...
Ricearu Posted June 23, 2011 Author Share Posted June 23, 2011 (edited) shiesty dallas roads took my fogs from me... :-\ both of them. and yeah my dogs are EJ - mother was pit/father was Jack Russel terrier 7 months old (he is liver aka yellow eyes and fur and lacking pigment on nose and ears) Frau - AKC German shepherd - 11 weeks old (typical German shepherd colors) Edited June 23, 2011 by Ricearu Quote Link to comment Share on other sites More sharing options...
bratclay Posted June 23, 2011 Share Posted June 23, 2011 Thinking about rippen all of the carpet out of subi and later on gettin that rubber mat stuff that is fitted for ur exact car:cool: Quote Link to comment Share on other sites More sharing options...
Ricearu Posted June 23, 2011 Author Share Posted June 23, 2011 replaced evap solenoid and knock sensor with junkyard parts and glazed the bad spots on my 15" outback wheels, then primed them. Now, for final primer sand and paint! if the weather and relatively low humidity hold this evening. Quote Link to comment Share on other sites More sharing options...
jboymechanic Posted June 24, 2011 Share Posted June 24, 2011 Put a new oil fill neck o-rings in in both my '95 and my '96, old ones were so hard they snapped during removal. No more oil leaks there. Put a new oil pressure sensor in my '95, no more oil leak there either. Finally, put new plugs and wires in the '95 and to my shock I found the current plugs to be in finger tight! Needless to say the car runs much better and has more guts, the previous owner was a real gem! Quote Link to comment Share on other sites More sharing options...
T'subaru Posted June 24, 2011 Share Posted June 24, 2011 I put LEDs in mine too, sorry no night time shot... Time to pull some codes ? Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 24, 2011 Share Posted June 24, 2011 Time to pull some codes ? Time to pull the bulb Quote Link to comment Share on other sites More sharing options...
czny Posted June 24, 2011 Share Posted June 24, 2011 (edited) Replaced the rear cat converter on my 87 GL 4WD wagon today. It had developed a really annoying rattle in the exhaust, especially when just warming up, that would quiet down when exhaust was hot. Pulled the rear pipe with cat, shook it hard & the biscuit came loose inside. Cheaply made cats just don't last. The biscuit was so loose it turned sideways inside the body. Chopped it out right next to the cat body. Replaced it with a Magnaflow 91004 (same length+width+depth as original but 2" in & out). The 91004 has only one heat shield so I liberated one from the old cat, tack welded that to the new cat. Aligned everything in the exhaust, tacked it together then removed the assembly for final welding. Put assembly back in, checked alignment so nothing hits & cinched down the hardware. Found out later that the Magnaflow 38104 will also work for this application. No more noises like chicken bones in the garbage disposal. Edited June 24, 2011 by czny more info Quote Link to comment Share on other sites More sharing options...
heartless Posted June 24, 2011 Share Posted June 24, 2011 Replaced the rear cat converter on my 87 GL 4WD wagon today. Someone please correct me if I am wrong, but I thought that the 80's models only had one cat converter - at the Y-pipe junction. At least that is what my 89 GL had (and the 89 GL DR 4whl dr and the 88 GL 3 dr, and every other Subaru from that era I have ever seen) after that there should be a resonator and a muffler - not another cat. Quote Link to comment Share on other sites More sharing options...
987687 Posted June 24, 2011 Share Posted June 24, 2011 Time to pull some codes ? I fixed the CEL, it was a broken vac line at the charcoal canister. And the ABS light is because the fuse for the windshield wipers blew while driving in the rain. And that was the least important fuse to steal. Quote Link to comment Share on other sites More sharing options...
czny Posted June 24, 2011 Share Posted June 24, 2011 Someone please correct me if I am wrong, but I thought that the 80's models only had one cat converter - at the Y-pipe junction. At least that is what my 89 GL had (and the 89 GL DR 4whl dr and the 88 GL 3 dr, and every other Subaru from that era I have ever seen)after that there should be a resonator and a muffler - not another cat. This 87 California SPFI EA82 GL d/r has TWO cats, one at the Y behind the engine & a 2nd cat just behind the trans. It also has the "light truck" category emissions sticker under the hood - a term rendered meaningless by the newest emissions laws here. Quote Link to comment Share on other sites More sharing options...
heartless Posted June 24, 2011 Share Posted June 24, 2011 This 87 California SPFI EA82 GL d/r has TWO cats, one at the Y behind the engine & a 2nd cat just behind the trans.It also has the "light truck" category emissions sticker under the hood - a term rendered meaningless by the newest emissions laws here. Ok, cali spec is a bit different...especially to those of us in the midwest. thank you for the clarification. Quote Link to comment Share on other sites More sharing options...
Ricearu Posted June 24, 2011 Author Share Posted June 24, 2011 got my outback 5 spokes painted a very subtle gold and having them wrapped with 195/50-15's today. This ought to be good! I will post pics with them on when I install them this evening! Quote Link to comment Share on other sites More sharing options...
Eatmore Mudd Posted June 25, 2011 Share Posted June 25, 2011 Replaced the front wheel bearings. Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted June 25, 2011 Share Posted June 25, 2011 Replaced the front wheel bearings. I have to do that too... and both tie rod assemblies. Pretty easy stuff at least Quote Link to comment Share on other sites More sharing options...
987687 Posted June 25, 2011 Share Posted June 25, 2011 Found out there are at least three different types of male rear axles... Grumble grumble Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 25, 2011 Share Posted June 25, 2011 noticed my car is overheating more now.. not sure how a engine lift is going to fit in a sedan if I have to take this other car... Car stumbled after I moved the fluid back over to the radiator would I would guess mean coolant is getting into the cylinders now. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 25, 2011 Share Posted June 25, 2011 Got these from a Junkyard for $50! Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 25, 2011 Share Posted June 25, 2011 Jus got done yarding the engine from my XT6. 15 minutes from hookin the hoist up to on the stand. Now I'm starting teardown for a complete reseal, timing belts, clutch and more. I washed my new '89 1/2 black RX the other day though... Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted June 25, 2011 Share Posted June 25, 2011 (edited) @ Caboobaroo PM Sent Edited June 25, 2011 by Crazyeights Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted June 25, 2011 Share Posted June 25, 2011 Got an SPT catback for my WRX today! Quote Link to comment Share on other sites More sharing options...
Ricearu Posted June 26, 2011 Author Share Posted June 26, 2011 Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted June 26, 2011 Share Posted June 26, 2011 Looks so good I had those same wheels on my Impreza coupe painted gold, and it look amazing as well! Looks like I have to get gold five spokes for my lego now, I'm thinking forester 16's though.... Quote Link to comment Share on other sites More sharing options...
