Ricearu
I have determined that I have neglected mine.
And that the valves on my friend's car are hosed on
one cylinder.
So I tried to fix, found out it was beyond what I wanted
to fight with and beyond what she wanted to fork out.
Twitch
PS: Said friend's car is for sale in the Classifieds.
Share this post
Link to post
installed Timing Belt kit on the BAJA which i have for sale.
I give you 100 bucks for it :lol: Plus my broken GL-10, its an offer that you cant refuse!
Share this post
Link to post
That is a great idea! wow, Will have to see how it holds up (I dont have a rust problem in my main brat (Texas) but my trailer brat is rusted bad..., I will try this... Where did you get the vinyl?
-Daniel
I got the vinyl from a friend but you can probably get it at one of those large home improvemnt store's. You want the rigid stuff that you can hardly bend. That's what I used anyhow. I made the template with a piece of old newspaper. Traced the outline onto the vinyl with a laundry pen and cut the vinyl with large scissor's. I used a few of those short self tapping screws to hold it in place while the glue dried.:banana:
Share this post
Link to post
Fixed two things in one day so it was a good way to close out 2010.
Finally replaced my hood release cable so I could put my grill back on after the cable broke 4 months ago. Then pulled the rear window wiper motor and regreased it. I have never seen the rear window wiper move so fast before!!! :banana:
Share this post
Link to post
I gots my tranny semi Bolted in. Now to make tranny mounts, have a drive shaft made, and put in a new rear diff.
Share this post
Link to post
Put a new Dual radio/cd player into the Brat to replace a Pioneer cassette player that wasnt hooked up when I bought it. Realized later that the red acc cable wasnt acc as in amp or subs, but has to be tied to ignition or whatnot :)
Bought some Rustoleum bedliner as a preventative measure against rust but its too cold to put it on at the moment.. was happy to see someone had sprayed an undercoat of the same stuff around the wheel wells, no cancer in this one ^^ Had to sand and spray the metal skid plate for the bed though, now is nice and shiny black.
Share this post
Link to post
I got the headgasket finished on my wifes 99 OBW. First time doing it. Besides some setback, I found it to be relatively easy. Now I am looking for another 2.5 to rebuild and put in my Forester. I think I am hooked on semi-rebuilding engines.
-Lance
Share this post
Link to post
I welded up a leak in my dual exhaust that was right in front of the glass pack. Did a horrible weld job but hey the bigger the glob the better the job. Also put some walmart high tech seat covers on. But I think my tranny is on its last leg.
Share this post
Link to post
A lot! rear five lug on my brat, refinished alloys for it, working on the subframe right now tying to get ea82 control arms to fit it, got an AWD trans, got the franken motor somewhat together (still need to do the timing belt and bolt the intake on) I also had to change my radiator hoses on my 92 legacy after I had a bit of a steamy mess one night. (I probably should change them before they explode next time :drunk: )
Share this post
Link to post
Does starting him count?
Justy sat for 2 months in bitter cold weather and a blizzard. Took more cranks then i expected but it ran fine except idle is 1500 RPM.
Share this post
Link to post
Broke mine in a bit. Took it for the longest drive ive done since i got it. Ran good the whole time.
Also ordered new hatch lift supports and arranged my tools(my hydraulic jack, tow strap AND 25 ft jumper cables fit nicely in the floor compartment :banana:). Also put my 15" sub in the back, just waiting to find an install kit to put in one of my spare radios and wire up the amp.
Share this post
Link to post
Finished instaling the ea82 control arm mounts on my ea81 subframe! :headbang:
2-7.jpg?t=1294282640
1-10.jpg?t=1294282640
Five lug and legacy brakes here we come!
Share this post
Link to post
I changed the oil and filter (10w30 Valvoline synth and scoob filter) on the 87 GL. It really likes the slippery stuff.
Also, the legacy outback has a new driver's side heated power mirror on it's way in the mail, so I took the door apart and popped off the broken one preemptively.
Now to fix this dang computer. :)
Share this post
Link to post
Replaced the left outer and inner tie rod ends in my legacy. It better pass inspection now
Share this post
Link to post
my buddy had some dual blade wipers for his rig but they were the wrong size so i modified my wiper clips to fit em. work pretty damn good :D
Share this post
Link to post
dual blades cause lots more strain on the wiper motor and over time will cut its life short. too much friction with the extra blade.
be careful with that type mod. you can read up on this on the google.
Share this post
Link to post
changed plugs, wires, cap and rotor, new alternator, removed PS and AC belts, ordered new lift supports, changed fuel filter in engine compartment, need to change other fuel filter by fuel pump.
Share this post
Link to post
Last weekend I replaced the transmission and diff fluid in my RX with Redline 75W90NS. While under the car I noticed the outer right front CV boot had cracked so I had that replaced today. Since I had a coupon for a free oil change from the shop I use, I figured I would let them do that too. I need to address to oil leaks at the front of the engine sometime. It will have to be after this semester, at least.
Share this post
Link to post
Patched the cracked dash and covered with some leftover thin carpet. Filled the missing vents with a bit of sky! Still needs a bit of work to cover the cracks in the visible edges
Share this post
Link to post
Create an account
Register a new account
Sign in
