I finished my EJ22>Loyale swap and ran into a problem with the motor mounts.  The old mounts split because of the different angle between the cross members on the Legacy vs the Loyale.  The mounts on the EJ22 fit into a flatter v in the cross member.  The Loyale cross member has steeper sides to the v where the engine sits.  The angle is 21 degrees on the Legacy vs 30 degrees on the Loyale.  This caused the mounts to split and separate on the lower inside area.  After driving a little the spl
