MilesFox Posted January 21, 2005 Share Posted January 21, 2005 i got a spider intake and i want to explore the possible use on the rx. as we know the rx has a carb motor now, but the turbo harness is still intact. the reason it has a carb is because the MPFI wen out in some way shap eor form on the car itself(the motor works in another car now) i figure if the wiring harness is bad, i can isolate the ecu connectors and connect them directly to the motor. i may try my installation without the turbo at first, using a carb block. i do have an mpfi non turbo long block, but i'll save that for use with the 97 regular intake leftovers what i want to know is do these manifolds work the same with one ecu? i do have the ecu to the spider, i wopuld want to use the one in the car already, or swap the ecu if the plug ins are the same i anticipate using an xt6 throttle body, are the connectors the same or will i have to splice a connector. wat about xt6 MAF? and for use of a turbo, what would you use to plumb the turbo. my setup is from a mpfi non turbo Quote Link to comment Share on other sites More sharing options...
Forkspear Posted January 24, 2005 Share Posted January 24, 2005 I have a spider intake on my 87 rx. I am using the rx computer. I used the lower half of the manifold form a turbo spider xt. The upper half from a non turbo with no egr. I also used the motor wiring harness from the turbo xt. It has the same plugs as my rx I used the factory turbo plumbing until I intercooled it. It is a black plastic pipe from the turbo to the throttle body with a place for the auxillary air valve hose. You might use 3 elbows and a reducer. I have an xt6 throttle body that I plan on using sometime. The bolt pattern is a litte wider than the raised area the throttle body bolts to. The tps looks way different. The connector looks the same but I haven't plugged it in to check. I didn't look at the xt6 maf to close. It looked the same on the outside. I have looked at a 300zx turbo maf. It is larger(3") and the connector looks the same. Im thinking about trying the maf and injectors from the 300z. good luck Quote Link to comment Share on other sites More sharing options...
