2subarujustys
  1. I recently swapped the engine from a 1992 Justy (FWD) with an auto. trans. to a 1990 Justy (4WD) with a manual trans. There was no engine or engine wiring harness in the 1990, so I used the harness out of the 1992. The main engine harnesses went right together but I had to swap the connector for the alternator. It had a different configuration, so I changed the connector end. It initially ran fine but after about 10 miles, it wouldn't restart. There are codes for a bad cylinder designation sensor, and a bad crank angle sensor. I was wondering if anyone had ran into this problem before. The engine wiring might be different from the auto. to the manual trans options. The wiring schematics that I have accessed have the wire colors listed, but they don't jive with what's in the car. Sincerely.... Rick Bredijk kjiderbh@sti.net
