petroski
  1. 5 speed 4wd hooked to an ea71, is the fifth gear overdrive or 1-1?
  2. The mainshaft seal. I've never had to replace one before. This will be the second engine rebuild for this wagon, so its got a few miles on it. and the trans is leaking ( I'M TALKING ABOUT BIBLICAL PROPORTIONS) from behind the throwout bearing. Clymer shows installing the seal with the mainshaft during final assembly. I believe I would buy good a used trans before I dissassemble this one to replace a seal!
  3. Greetings all, Anyone out there ever replaced the front transmission seal in an old style, 1979 4 speed? How much trouble was it? Thanks, Ski
  4. Greetings all, Seems I've lost my chilton. Can anyone tell me the torque specs for the rod, head and case bolts/nuts for a 79 1600? Thanks, Ski
  5. Thank You Redscab! I Have Never Had Both To Compare. There Is A Set Of Rebuilt E 81 Heads And New Rocker Arms Currently On Ebay If Anyone Else Is Intrested. I'm Rebuilding My 79 1600 As We Speak. Thanks Again
  6. Greetings all, I'm wondering if anyone knows if e 81 heads will fit/work on a e 71 block? Thanks, Ski
