christopherlee
  1. Sweet site... found some more info...thanks im checking ebay now...will post and let yall know how it goes!http://www.ultimatesubaru.org/forum/images/smilies/burnout.gif i think i may have figured out the turbine... i just am not sure if the exhaust side fan is permenantly attached to the shaft. Will try some heat though. Thanks to you as well...
  2. I installing a JDM EJ20TT into my brighton edition 97 impreza currently with an EJ18. Has anyone done this conversion? Are there any unforeseen challenges other than the need to relocate the driver's side turbo closer to the motor? Additionally, I don't have an ECU for the new motor? I was thinking of putting in some variable resistors to adjust the O2 and MAF before sending the signals to the original ECU... will this work? Lastly, when I got the motor, the passenger turbo had an oil leak. I am currently rebuilding this one and am at a point where I cannot determine what to do next. I am having trouble getting the turbine off. Any suggestions would probably help. Thank you!
