blmw
Everything posted by blmw
  1. You won't regret getting a great wrench!
  2. Still looking for a great gift? Well here you go!
  3. Time is wasting! Don't miss out.
  4. Still looking for a holiday gift? Well here you go!
  5. Get yourself a torque wrench - you won't regret it!!
  6. Time is wasting! Get yourself a great torque wrench.
  7. Looking for a great torque wrench (and a great gift)? Well you found it!!
  8. Get an early start to your holiday shopping and buy a great wrench!
  9. Bump for a great wrench!!
  10. Holidays are coming quick - and our wrench makes a great gift.
  11. Need a great holiday gift? Well here you go!!
  12. We ran this special awhile back, and the response was real good so we are running it again: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: ultimate You can see the torque wrench in action in the following video: Product Specifications Patented Double Gear Sensing System Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale) Microprocessor Controlled 8-bit electronics ensures accurate readings and simplicity of use Allows for both Peak and Track mode Individually calibrates each wrench Supplies unique serial number for each wrench Ratchet Head 1/2" drive reversible ratchet 32-tooth gear provides an 11.25º arc while handling high torque loads Forged from Chromium Vanadium alloy to ensure strength Conforms to ASME B107.10 2005 standards Range 15 – 150 ft/lbs 180 – 1,800 in/lbs 20.3 – 203 Nm Digital Control Large backlit digital display shows both target torque and current read-out Intuitive button design makes operating torque wrench simple LEDs and digital display provide visual feedback when operating wrench Buzzer creates audible feedback when target torque is reached Easily switch between ft/lbs, in/lbs, and Nm Automatically powers off when not in use for 2 minutes Low battery indicator Handle Soft-touch overmold provides comfortable non-slip grip Engineered plastics ensure an impact resistant housing The offer is valid until Dec. 31st, and is only for the lower 48 states. We are located in Chicago, IL. Phone is: 312-884-7644. Email: info@brownlinemetalworks.com
  13. Last day !!!!!!!!!!!!
  14. 15 Days remaining !!
  15. We do not currently sell one, but it is something we are working on - should be available later this year. BLMW
  16. The one on Amazon that is the same price is without the case. Amazon sells the case version for $119. In regards to the Country of Origin, the link that you post has the incorrect information (the correct is above). BLMW
  17. The ratchet and the steel components of the wrench are manufactured in Taiwan, and the electronics and assembly are done in Malaysia. Our repair / calibration facility is located in Chicago in case anything ever needs to be done to the wrench. BLMW
  18. Brown Line Metalworks is a manufacturer of Digital Torque Wrenches. We are offering members of this forum the following: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: ultimate You can see the torque wrench in action in the following video: Product Specifications Patented Double Gear Sensing System Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale) Microprocessor Controlled 8-bit electronics ensures accurate readings and simplicity of use Allows for both Peak and Track mode Individually calibrates each wrench Supplies unique serial number for each wrench Ratchet Head 1/2" drive reversible ratchet 32-tooth gear provides an 11.25º arc while handling high torque loads Forged from Chromium Vanadium alloy to ensure strength Conforms to ASME B107.10 2005 standards Range 15 – 150 ft/lbs 180 – 1,800 in/lbs 20.3 – 203 Nm Digital Control Large backlit digital display shows both target torque and current read-out Intuitive button design makes operating torque wrench simple LEDs and digital display provide visual feedback when operating wrench Buzzer creates audible feedback when target torque is reached Easily switch between ft/lbs, in/lbs, and Nm Automatically powers off when not in use for 2 minutes Low battery indicator Handle Soft-touch overmold provides comfortable non-slip grip Engineered plastics ensure an impact resistant housing The offer is valid until March 1st, and is only for the lower 48 states. We are located in Chicago, IL. Phone is: 312-884-7644. Email: info@brownlinemetalworks.com
