cracka
Posts posted by cracka
Because a th400 is easy. Works well. Is proven. Is cheaper, and already built.
T56 would be more expensive, need gay concentric clutch and be of no benefit to the car anyway
Original gearbox is an a340...nothing wrong with it. But dont have one.
the v12 and th400 is less weight forward than the ej. With full weight the car is sitting higher than before.
The cross member is probably about 200% stiffer in compression.
The chassis is reinforced across the width of the car, and the engine mounts are further outboard.
All in all...Car has less stress, an inherantly balanced v12 that doesnt even knock a coin off its edge when turning the starter motor over, and has its f/r weight balance moved further back with at most 20-30more kg total weight mainly from the R230 rear diff.
I dont think the strut towers are going to magically fall in, like some 1960's designed american chassis. I dont think the windscreen will implode. The car is stiff enough to jack one corner off the ground and still maintain panel and door alignment. This isnt a mustang, its a gen 3 liberty with gen4 reinforcement and a whole lot more.
So no, my comments were not naivety, they were in astonishment of such a stupid comment, and then an irrelevant comparison.
That said, I appreciate any criticism as the thing is nearing completion and its good to hear other peoples impressions and thoughts. A lot of the input is a result of passing comments Ive taken onboard.
What makes you think a giant hollow alloy block is much heavier than an EZ30, which the gen3 was also deigned for? (hint: it's 14kg heavier...).
I wonder how long before the strut towers meet eachother in the middle of the car or he pops a windsheild. You can't just plop a high output engine in a small car without beefing up the body.
This is my car.
And this is the dumbest thing I've ever seen commented about it.
That is all.
Define "insane": V12...
in Subaru Transplants
Posted
th400 takes the power and torque
is 1/2 the price of the 4l80 because its already built and rebuilt fresh from a turbo 1uz drag car.
I wont miss overdrive as I have 6 gears in my 3.0RB gen4 if I want to go anywhere.
The th400 is two clicks for 140mph skids. Exactly what the car is made for, leaving 11's everywhere for a laugh and nothing else.
