dan595
  1. The manifold is now with a local firm to me AlloyFabweld , it's not cheap , they want £30 an hour for 3 hours of work . I will post a pic when I have it back
  2. Have a look on the YOUTUBE for Barchetta 595 with Subaru EA81 motor Zcars
  3. OK many thanks for the input , cast ali welding seems to be the next stage . Thanks again guys
  4. I am certain I bought the correct adapter , its part #99004.110 which is listed everywhere as the right part , I can only guess that my ea81 manifold is slightly different for the UK market ?
  5. Hi I have an EA81 motor fitted into my Barchetta 595 . I decided to replace the Hitachi carb with a weber so ordered from the US the redline kit for the EA81 but the adapter plate does not line up with my UK manifold . Does anyone know of an adapter plate that can be used ? The studs on my manifold are approx. 78.5mm and 44mm apart . The ones on the redline #9904.110 are about 7mm different from this . Is there an adapter that can be modded easily ? I was even going to look into having the thing ali welded to the manifold but am not sure how expensive or successful this will be. Maybe someone out there has had the same dilemma .
