webrob
  1. I have installed the 15 amp fuse, I understand now that it makes the car only front wheel drive, the problem persists, so I guess the center clutch pack is locked up. Thanks for your input. Webrob
  2. Twitch So I finally got around to opening the FWD fuse holder, and there is no fuse in it at all. I will put a 15amp in as you recommended, but do you think that could be the entire problem? you see we just purchased this car used, around the first of December. Thanks webrob
  3. My 1992 Subaru Legacy L 4WD has an issue I need help figuring out; it slows down when turning sharply, in either direction, as in when turning into a parking place. Also when I am backing and turning sharply it sounds and feels as though it is applying the brakes. While turning sharply moving forward, I feel a vibration some times through the steering wheel. I just replaced front and back brakes, and there was no improvement. The boots on the CV are fine and I hear no clunking, the boots on the rack & pinion however are torn, also worth mentioning is the power light on the dash flashes more than 8 seconds at start up, indicating a transmission issue. Any ideas what could be the problem?
