Everything posted by Ponypuffprincess
Got a Subaru 1.8 as a newbie project. A few Q's please.
Well...found a '95 Impreza with a 2.2NA and 5 speed unmolested in a pullapart yard. Ready to yank that combo right now. 6" snow coming down. AAARRRgh!
Crazyeights, thanks for your candor. I had a nice review of the parts with my machinist and we came to the conclusion the block needed honing at $80, the crank needed grinding at $175 and then there's rings, bearings, seals. About the same $ as a used low mile 1.8 engine. Alls to be gained from rebuilding is the knowledge that there's new parts and I know the condition intimately. With the research I've done on Subie flat 4s, I've learned alot and still think my 1800 lb kit will do well with my chosen plan. Just maybe not this box of parts. I am thinking this'll be parted out and take the $$ toward a great 1.8 long block. Thanks for you all's input. I'll be looking around now.
Thanks guys. Again, this was a gift of a totally dissassembled engine given to me in boxes. I see I also have a knock sensor and am now told the engine came from a '97 Impreza. I am doing a year's worth of reading getting up to speed but this helps me figure out if this is worth a $400 rebuild budget (including 2.2 heads). So here we go: Can I find out from the dealer what car this came out of via the serial numbers? Looking at the block cast numbers of 91-2-3 and 92-2-4 do I have 2 different engine's block halves? And having the numbers AA 22212 and AB on the other block half could roughly guide me as to where to place the pistons? They came disassembled from the rods. And regarding the above, knowing rods, pistons, etc are all apart, should I need to balance the rotating assembly all over again? Or if the assembled piston assembly all weigh within a gram of each other I could theoretically skip balancing right? Or am I off on this one. Kindly appreciated.
Hello. I was just given a 1.8 NA engine, totally disassembled, and am having difficulty with first step. I'm a Ford type, so I'm diving into Subie territory. Please be gentle with me. I have been searching, and searching for info. I believe its out of a 91 Impreza. First: Best web place to ID this block? All I can see is cast numbers: 92-2-4 on one half, 91-2-3 on the other. and AA 22212 I can figure out eventually. Any other numbers I should look for? I cant find any Serial numbers.... I appreciate your pointing in the direction of a good place or book for research. Thanks.
