ib759
Everything posted by ib759
  1. Thanks Rally Suby, That helped me understand how the system works a little clearer. I did find the problem, it was the daytime running light modual. I replaced it with a used one and they work fine now.
  2. I checked all the fuses, they are ok. I hear the DRL modual click and the 2 relays in the fuse box under the hood click when I turn on the light switch. Is there also a DRL relay? I've read elsewhere that there is, and also a headlight relay. But I'm not quite sure where they are located.
  3. Update- Replaced the multifunction switch, this fixed the turn signal problem but the low beams still don't work. Just to be sure I replaced both headlight bulbs, with no success. Does anyone know, did all 2000 Legacy L models have daytime running lights?
  4. First time owner of a Subaru. First time member of a forum. Joined because I'm having a problem with my low beam headlights not working on my 2000 legacy sedan. Hi beams work fine. Tested the bulbs, installed 1 new one, but I'm confused by the fact that when I check for current with a test light I have current at all three terminals on the bulb sockets with the switch set to hi beam and the middle and one outside terminal with the switch set to low beam. Shouldn't the middle terminal be ground? I'm also having problems with the left turn signal. most of the time I have to wiggle the lever to get them to flash and then they flash about twice as fast as the right side. All the bulb seem to be fine, at least all the four ways flash.Is it the turn, light and dimmer switch? I'm open for sugestions.
  5. First time owner of a Subaru. First time member of a forum. Joined because I'm having a problem with my low beam headlights not working on my 2000 legacy sedan. Hi beams work fine. Tested the bulbs, installed 1 new one, but I'm confused by the fact that when I check for current with a test light I have current at all three terminals on the bulb sockets with the switch set to hi beam and the middle and one outside terminal with the switch set to low beam. Shouldn't the middle terminal be ground? I'm also having problems with the left turn signal. most of the time I have to wiggle the lever to get them to flash and then they flash about twice as fast as the right side. All the bulb seem to be fine, at least all the four ways flash.Is it the turn, light and dimmer switch? I'm open for sugestions.
