billyfrancis40
  1. Yah I think the solinoids I changed wasn't the right ones I just read today I have to possibly change the clutch pack and the solinoid duty c is on the tail of the trans and that's hopefully it can't really find the parts to order thou.
  2. Here all are codes today as of rehooking up battery P1718,p0134,p0700,p0763 Car is a 08 legacy none turbo with a 4eat trans I replaced the internal filter not the external one yesterday with about 4 qts of new fluid. Pan looks good but does have a very little dent on the external filter. At oil light flashes none stop and won't go away for nothing . No noticable wire damage but not sure where tcu is I think under dash by steering column and I followed those as well look ok. Got car from my dad which is original owner and he had it maintenance at subi deal for life of car. Car did sit for about a yr. He's had all done to it heads belts trans serviced and so on. Really confusing me. Really all this happened when a trans cooler line was leaking and we just cut where it was leaking and ran rubber hose instead of the metal rusty line inside the engine bay to the radiator. Since then the light has flashed like crazy. Thx
  3. Well I just got my dad's old legacy and it's not bad none turbo thou bummer but still nice. Having some issues and need some help with the stuipid auto trans at oil light flashing and codes for solinoids c and po700. I ordered new solinoids and installed with new fluid and filters but still prob won't leave. Car won't shift out of second gear even in sport mode any help will be appreciated thx guys I've tried clearing codes stored but keep coming back is their a way to reset the tcu I think it needs to relearn with the 6 new solinoids I installed. Anyone local to me in Ne Ohio that could maybe help. Do I have to flash the stuipid tcu or will just unhooking battery for a night do the trick because it hasn't so far. Can I just use a flash cable and download to files to flash it to clear.
