April 2, 201016 yr I have a '96 impreza coupe. 1.8 5spd. I made the mistake of ordering a short shifter from kartboy for a 97-01 impreza by mistake. Needless to say the shifter setup is compltely differentA! Rather then sending it back and paying 15% restocking fee, I decided to buy all new parts from a 97+ 5spd. Iv'e ordered the trans rod so I can matt that with the newer short shifter and ive ordered the bushing that goes at the bottom of the short shifter from a 2002, I was told it's the same from 97+. The shifter bushing does not work in my factory shifter rod, If I order a shifter rod out of a newer impreza, would this work with the new bushing and short shifter? I could have saved money & time by ordering a complete impreza short shifter fully assembled for $240. Edited April 2, 201016 yr by subinut24
April 3, 201016 yr I have a '96 impreza coupe. 1.8 5spd. I made the mistake of ordering a short shifter from kartboy for a 97-01 impreza by mistake. Needless to say the shifter setup is compltely differentA! Rather then sending it back and paying 15% restocking fee, I decided to buy all new parts from a 97+ 5spd. Iv'e ordered the trans rod so I can matt that with the newer short shifter and ive ordered the bushing that goes at the bottom of the short shifter from a 2002, I was told it's the same from 97+. The shifter bushing does not work in my factory shifter rod, If I order a shifter rod out of a newer impreza, would this work with the new bushing and short shifter? I could have saved money & time by ordering a complete impreza short shifter fully assembled for $240. Yeah, seems like you fucked up pretty bad there ahwel thats the way things go. If I were you, I would cut your losses, pay the restocking fee, and take this as a lesson to get the right part first. Sort of the "measure twice, cut once" philosophy, saves you a lot of wasted cash and effort. Good luck PS: Just wondering, why do you need a short shifter? No offence but the EJ18 doesn't seem like the ideal performance engine... Do you just like the feel of a short shift or do you have a performance engine going in at some time? Edited April 3, 201016 yr by rxleone
April 3, 201016 yr Author Yeah, seems like you fucked up pretty bad there ahwel thats the way things go. If I were you, I would cut your losses, pay the restocking fee, and take this as a lesson to get the right part first. Sort of the "measure twice, cut once" philosophy, saves you a lot of wasted cash and effort. Good luck PS: Just wondering, why do you need a short shifter? No offence but the EJ18 doesn't seem like the ideal performance engine... Do you just like the feel of a short shift or do you have a performance engine going in at some time? Well I do like the feel of the short shift, I also know the ej18 engine is to say the least a gasemeizer engine & not a fast & furious version. I did plan to transplant either a rs 2.5 engine or the 2.0 turbo engine. I'm going to keep the short shifter wether things work or not, I service & sell subaru's so there's bound to be another subaru I can use the shifter in.
April 3, 201016 yr Well I do like the feel of the short shift, I also know the ej18 engine is to say the least a gasemeizer engine & not a fast & furious version. I did plan to transplant either a rs 2.5 engine or the 2.0 turbo engine. I'm going to keep the short shifter wether things work or not, I service & sell subaru's so there's bound to be another subaru I can use the shifter in. If I were going with a EJ20G or EJ205 I would definitely use the gearbox and clutches that came with them. They're a pull type hydraulic clutch, not the push type used with non-turbo EJs. I've seen a 89 RS engine (single turbo EJ20) destroy several clutches and finally the gearbox in an EJ Dual-Range gearbox setup. No dumped clutches either, just too much power and torque.
