aftermarket speedometer
Where would i hook up a aftermarket speedometer sensor cable to?
cable mounts to the passenger side of the trans, somewhat towards the top.
you can retrofit a speedo sensor from a later model car, if you are using an aftermarket speedo that is electronic instead of cable
