New here.
Found this forum threw Google. I got my Outback from the Auto salvage yard I work for. It was going to be crushed. It seemed to run just fine at first but started to have head gasket problems. I pulled the engine and did the head gaskets in my spare time. The car has 267,000 miles but the engine still had a very strong cross hatch in the cylinders. It seems that it has had a rebuilt engine installed. The engine had the timing belt guide that was only used on the manual trans cars. Mines an auto trans.
F1A01AEF-F152-47FA-BB39-2FA9E1265364-257
3BEBBD45-0715-432C-AFA2-222889ABBA71-257
2F662702-AB36-4D12-9E7F-481FD7FEF70A-219
Thanks for the forum help Shawn.
I can attest to you that the crosshatches are most likely the original engine and wear. Crosshatches never wear out, and rebuilding a block is never necessary unless there is an obvious bottom end knock, ehre it is more economical to source a used block instead of a rebuild. You can get 400,000 miles out of that block if you take care of it, which it look like you are on the road towards!
Keep us updated as i love stories of cars rescued from junk to live on for many years and miles.
side note- That timing belt tensioner can be converted to one style or the other simply by switching the bracket that it mounts to.
Edited by MilesFox
I was talking about the guide thing in the pic. I was told that they didn't use them on auto trans engines. Wish the engine was the single cam one. The DOHC is kinda a pain in the rump roast with the valve shims.
Spent a little time looking around on the forum and I like this place. I really like the section for old Subaru's. Some I've never seen before and some I haven't seen in person for a very long time.
Consider ej22e heads (f you got them) SOHC for a little compression bump1990-95. You would have to use the ej22 intake but it matches the wiring harness.
I can get my hands on the single cam heads but will I have to run 93 gas ?
You will have to run higher octane fuel. You can priobably get b on lower octane or middle octane, but the ECU will pull timing so it could be doggy under load. It's a common upgrade to get out of the issues associated with the ej25d
Thanks for that great info. The only down side for me is that I won't be able to use the free gas at my work .
You could add a can of octane boost. I frankenswapped my forester after it had a full tank, so i used octane boost to run it out. (for some reason i thought you were in australia, thinking your car was RHD)
I'm in the US but it would be cool to have a RHD car here. I've read some on here that the single cam heads fix the head gasket problem. I thought using a MLS head gasket on the DOHC takes care of that problem. There seems to better knowledge on this forum then on some of the other forums.
Hi i am a newbie here guys. Happy to join the forum!!
Edited by louisefleming
