Gen 1 & 2 Front Struts - Are they still available?
I have Gen 2 struts on my 79 sedan.  They fit fine.  The overal length is about an inch shorter but that suits me fine.  These are ajdustable so you can always lift them a bit if you need.  The travel is the same as Gen 1.
Alternitavely you can put new inserts in your old struts.  I have done this too.  It took a little fiddling but I made it work.
Cheers
Dirk
OK, Thanks, ordered some Gen 2's from autopartswarehouse.com, couldn't beat the deal, $75 shipped total for the pair.
Part #: GABG55726
GABRIEL ULTRA SHOCK ABSORBERS AND STRUT ASSEMBLIES
Gabriel Ultra
Twin-tube Shock Absorbers and Strut Assemblies have 1 3/8" bore pistons
(in most applications) and bonded iron structures safeguarding a long lasting
durability. Th Shock Absorber and Strut Assembly
Gabriel
Qty: 2.00
Price: $ 37.93
  • 2 weeks later...
Got the Gabriel struts in, I will post info after the install.  At first glance it looks like they will work.  The first place I orderded them from returned my $ annd said they were out of stock.  Looks like these may also be going obsolete soon.  I ended up getting some off Amazon for under $100 for both shipped.  I noticed the part number on the strut was different than the one on the box, I will pass on that info on also.
Edited by sancofw
  • Like 1
