August 12, 201411 yr I was given a starter presumably form an 87 gl or 92 loyale 5spd to use as a replacemetn in a 96 impreza 4eat. It works. I figured it would, but i had a doubt for a minute. I should have known this already. Well, i guess i did since i went after it. The original starter has a bullnose and a different starter body and solenoid.
August 12, 201411 yr I recall something different between them, perhaps the depth of engagement.. but its been a few years since I measured them on the bench. But hey, if it works... it works right.
August 13, 201411 yr Author Come to think of it, my ej swapped 3door with RX trans has a bullnose starter. I did have to space some washers for engagement, but because EJ swap
August 26, 201411 yr I do know there are 2 different sizes of hole in the bellhousings. Starters have a cast ring that seats into the hole, some are small and some are larger.........can't really say which is which but there are basically 2 types of subaru starters.
