hancho3 Posted February 22, 2009 Share Posted February 22, 2009 I have an 81 Brat Gl ea81, and it seems the only way to get juice to the ignition coil is to jump a hot wire from the +bat to the +coil. When I do this the dash warning lights and chime come on. When I use the ignition switch without hot wiring the only thing that works is the starter. I would really love to make it work with the key switch. Any Ideas? BTW I have yanked all of the weird emmisions stuff and put on an ea82 manifold with a weber. and I believe it had california emmisions as well so maybe there is something weird going on with the harness? thanks, -Kurt '81 Brat GL Quote Link to comment Share on other sites More sharing options...
hancho3 Posted February 22, 2009 Author Share Posted February 22, 2009 OK Problem solved the little fuse holder deal had become disconnected from the plug beind the fusebox Quote Link to comment Share on other sites More sharing options...
