April 22, 200916 yr Hi all , I wish to run the slightly better 87 hotwire engine spec cams in an 87 spider turbo engine I've had rebuilt . I believe the turbo cams are 14-56 56-14where the NA ones are supposed to be 16-60 60-16 . I checked through Subaru and the part numbers are different for the 88/89 MPFI NA cams compared to the 87 MPFI NA ones . I really really need to know what the 88 and 89 L series Factory Subaru workshop manuals quote as MPFI NA cam specs for those years . MY 87 L FSM shows a single ring in the "B" id position and two in the "C" position . If basically all these EFI NA cams are the same spec then the right ones should be easy to get . Also BTW I read that in 1986 only one of the EA82 NA's had 8.5 to 1 CR pistons std , were these carby or MPFI and would anyone have the genuine part number for them ? Cheers and thanks , Adrian .
April 23, 200916 yr the NA ones are supposed to be 16-60 60-16 . I checked through Subaru and the part numbers are different for the 88/89 MPFI NA cams compared to the 87 MPFI NA ones . I really really need to know what the 88 and 89 L series Factory Subaru workshop manuals quote as MPFI NA cam specs for those years . MY 87 L FSM shows a single ring in the "B" id position and two in the "C" position . My 87 USDM FSM shows the same specs for 87 NA MPFI as the 88-89. 16-60-60-16 Although the markings are different. For 87 it's *A* in the A mark, 1 ring at the *B* mark, and 2 rings at the *C* mark I don't have an 88 XT FSM. For 89 it's *A* in the A mark, None in the *B* spot, and 1 line in the *C* spot. Don't know if that helps.
